586,494 active members*
1,615 visitors online*
Results 1 to 4 of 4
    Jan 2019
    1
    Parameter required
    Team,
    We used Takisawa turning center with fanuc control. When edit mode or MDA mode after correction, if gobach to memory mode program must run from beginning only, currently not happen, how to solve?
    Dec 2009
    958
    Re: Parameter required
    what control type?
    Check the ladder for coil G 8.6 and see if the bit comes on with Mode change. (assuming 16/18/21 type of controller).
    Hello,, i m newer to this zone,, Recently brought old Takisawa-Ts15 with fanuc 6t controller. But unfortunately battery drained off and parameter vanished from machine. Need parameter to restart the machine .Please help me out
