586,754 active members*
7,556 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > RS232 cable diagram for SL-2 with Yasnac 2000G II
Results 1 to 9 of 9
    Apr 2004
    353
    Anybody have the wiring diagram to make up a cable for this machine/control? The machine has a 25pin female port on it inside the tape reader.
    Thanks!
    2932
    Be careful... IIRC some of the old Yasnac's had DB25 connectors that were intended for use with a Facit parallel punch, not serial I/O.
    But if it truly is a serial port, the cable should be:
    DB25M (CNC) <------------> DB9F(PC)
    1 <---------- shield --------- (no connection to PC)
    2 <---------------------------> 2
    3 <---------------------------> 3
    7 <---------------------------> 5
    4<>5 (CNC end only)
    6<>8<>20 (CNC end only)
    Apr 2004
    353
    Thanks!
    Any tips on how to initiate the program transfer to the machine? this control is new to me and my documentation is minimal.
    2932
    Hold off on making that cable. I just found another diagram and now I'm confused.
    Apr 2004
    353
    Ok so it looks like the serial port on the machine is in face for a tape puncher.... Any way to confirm for sure that this machine does not have RS232 program transfer capability?
    2932
    I googled Yasnac 2000g-II serial and got this.
    http://g-zero.com/G0Help/MiscComm/CN...ASN2000GII.htm
    IIRC, these guys had one or two of these Yasnacs, so I think they know what they're talking about. You might go to Fry's or Radio Shack and get a cheapie RS232 tester and try punching a program to see what pins flicker... if it's 15/16 as opposed to 2/3 (the usual xmit/recv pins) I guess I would try their cable.
    Apr 2004
    353
    I got a tester and tried to punch a program. No lights came on at all.
    I checked all the parameters that relate to RS232 and they are set to what that website was showing.
    I don't know what the history of this machine is, but it doesn't look like the tape reader was used for quite some time. The 25pin port beside the tape reader says "P.O." Beside it. Hinting at "punch out"? For a tape puncher perhaps?
    Jun 2004
    236
    Re: RS232 cable diagram for SL-2 with Yasnac 2000G II
    Try this, Plugs were configured backwards
    Use your tester at the computer end, I will not operate on the machine end
    You have to make a cable to communicate, Never Have I been able to go any faster than 300 baud
    But think about it, Lathe Programs are generally short
    Connector at machine
    Frame Ground pin 14
    Ground pin 19
    Transmit pin 15
    Receive pin 16
    jump 17&18
    Par N59 X3 Z54734 I0 K0
    Be very careful fiddling with this stuff, One mistake not documented will render your machine worthless
    following is the complete parameter set out of my SL-1 H
    Reference only if you get yourself in trouble
    Suggest once you get it operating, Start receive 300 baud 7,E,2
    Rotate to Edit, Simultaneously hit OFS and TAPE OUT, this will punch your parameters to you PC or LAPTOP
    Entire set for my SL-1s, Sl-2 and SL-3 these communication parameters will be valid for all with 2000 GII
    Complete Set
    N1X0
    N2X1
    N3X1
    N4X0
    N5X0
    N6X2
    N7X6
    N8X0
    N9X1
    N10X0Z0I0K0
    N11X0Z0I0K0
    N12X0Z0I0K0
    N13X0Z0I0K0
    N14X0Z0I0K0
    N15X0Z0I0K0
    N16X0Z0I0K0
    N17X0Z0I0K0
    N18X0Z0I0K0
    N19X0Z0I0K0
    N20X0Z0I0K0
    N21X0Z0I0K0
    N22X0Z0I0K0
    N23X0Z0I0K0
    N24X0Z0I0K0
    N25X0Z0I0K0
    N26X0Z0I0K0
    N27X0Z0I0K0
    N28X0Z0I0K0
    N29X0Z0I0K0
    N30X78500Z59800I0K0
    N31X-6500Z-215200I0K0
    N32X0Z0I0K0
    N33X0Z0I0K0
    N34X0Z0I0K1
    N35X0Z0I0K0
    N36X53Z107I4K4
    N37X0Z0I22K0
    N38X0Z0I2K34
    N39X8191Z565367I132K196
    N40X8
    N41X1
    N42X0
    N43X0
    N44X2
    N45X0
    N46X0
    N47X0
    N48X0Z0I0K0
    N49X12004Z1I4K0
    N50X15
    N51X4
    N52X25
    N53X50
    N54X25
    N55X0
    N56X0
    N57X6
    N58X1Z0I0K0
    N59X3Z54734I0K0
    N60X0Z0I0K0
    N61X1Z0I0K0
    N62X2Z1I0K0
    N63X32Z32I0K0
    N64X8192Z8192I0K0
    N65X0Z0I0K0
    N66X0Z0I0K0
    N67X400Z800I0K0
    N68X0
    N69X10
    N70X0
    N71X0
    N72X0
    N73X0Z30I500K500
    N74X0
    N75X0
    N76X20
    N77X8Z8I0K0
    N78X0
    N79X0
    N80X1
    N81X0
    N82X1
    N83X1
    N84X1
    N85X0
    N86X5000Z0I0K0
    N87X0
    N88X0
    N89X1
    N90X18Z5I0K0
    N91X0Z0I0K0
    N92X0Z0I0K0
    N93X53Z107I0K0
    N94X535Z1070I0K0
    N95X25Z45I0K0
    N96X30Z15I0K0
    N97X1770Z1000I0K0
    N98X40
    Apr 2004
    353
    Thanks for all this. I will give it a go
    I will be using a 25p to 9p converter to go to my USB serial 9p adapter. This wiring configuration should still be ok with my setup?
  1. Have a sl1 with yasnac 2000g
    By blakemachine in forum Mori Seiki lathes
    Last Post: 06-10-2012, 07:21 PM
  2. Miyano 7BC, Yasnac 2000G Wiring Diagram .. newbie here
    By roboy in forum Uncategorised MetalWorking Machines
    Last Post: 12-29-2008, 04:56 PM
  3. Yasnac 2000g
    By got_woody in forum DNC Problems and Solutions
    Last Post: 08-16-2008, 10:31 PM
  4. Help on Yasnac 2000G
    By ktb100 in forum DNC Problems and Solutions
    Last Post: 07-05-2008, 03:31 PM
  5. Wiring diagram for Mori Seiki TL5 with Yasnac 2000g control
    By frank12933 in forum DNC Problems and Solutions
    Last Post: 04-21-2008, 07:30 PM
