587,011 active members*
3,743 visitors online*
Results 1 to 15 of 15
    Mar 2006
    17
    Benchtop CNC mini lathe
    HI All
    Looks like an 8x14 at 229lbs with a 4" chuck
    This should be interesting
    frank
    Product Features
    1. This CNC precision mini lathe is designed to perform various types
    of processing jobs. Counterface turning, drilling, threading and
    cutting jobs on materials made up of round bar and bar materials can
    be performed with this machine. This machine can be used in areas
    such as mini precison parts processing, sample processing and
    modeling works
    2. This machine is DC motor driven
    3. The feed speed can be adjusted according to the requirement of
    different workpieces, the maximum feed speed can be reached to axes
    Z: 3 m/min, axes X: 2m/min
    4. The spindle speed is infinitely variable from 100 to
    2500/3000/3500RPM programme set)
    Specifications
    Distance between centres 350mm
    Swing over bed 200mm
    Spindle taper MT4
    Tailstock taper MT2
    Chuck diameter 100mm
    Spindle bore 25mm
    Cross slide travel 72mm
    Tool post size 60*60mm
    Cutter size 10*10mm
    Range of metric threads 0.5-2.5mm
    Range of imperial threads 12-52TPI
    Spindle accuracy 0.01mm
    Spindle speed 100-2500/3000/3500RPM
    Power of motor 750W
    Voltage/Frequency 230V/50Hz or 120V/60Hz
    Net weight/Gross weight 104Kg/130Kg
    Packing size 1055*575*570mm
    link
    http://www.made-in-china.com/china-
    products/productviewXeoJnFxrIQtP/CNC-Mini-Lathe.html
    company Shanghai Futai Electromechanical Equipment Co., Ltd.
    Mar 2004
    1306
    THis will be interesting to see. The MT-4 spindle is a real advatage. If you think about it, there are a lot of parts in a manual lathe (change gears, tumbler reverse) etc which can be replaced by a simple stepper, mount and coupler....
    I wonder what software they ripped?
    Mark
    Mar 2004
    106
    Really nice little lathe I like the chip guard.
    Do you know the price?
    CrazyRonny
    Jan 2006
    60
    I also want to know the price point on this thing?
    Mar 2004
    1306
    I wouldn't mind betting that ball screws were not used.
    Mark
    Jan 2006
    60
    I haven't seen the price point yet but I'll bet that they weren't used either. There seem to be more options every day.
    How would I get my big fat hands in there to clean it?
    There does'nt look like much space between the bottom of the machine and the chip pan!
    It looks like a traditional 4 position tool post, is it auto-indexing, or do you move manually?
    Eric
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    May 2005
    2502
    Intriguing little machine. And yes, it sure looks like an 8x18. There are a couple of nice upgrades in there, such as a camlock on the tailstock instead of just tightening a screw. I find it intriguing that the cross-slide servo/stepper drive looks like a right angle drive. Not sure what the backlash implications of that would be!
    I do believe the 9x30 and shorter bed 8x18 variant are the best CNC platforms among the mini-lathes. They are more heavily made than the 9x20's (they don't require the compound modification for rigidity), and the dispense with things like quick change gears out of the box.
    Widgit, there is more room than you'd think to get under the bed as it sits on two pedestals at the ends. The middle is hidden by the chip guard and apron, but I'll bet that guard flips up somehow. The travelling guard design would be nifty for anyone with one of these lathes. The controller also looks nicely integrated on the front.
    Somehow the chuck looks small to me. The spec says 100mm, which is just under 4". Also, not clear how productive a CNC machine like this would be commercially with some form of bar feeder. It would be perfectly adequate for prototyping, however.
    Best,
    BW
    Jun 2006
    424
    That's almost a 1inch spindle bore. Looks cool. What is the price and where do people buy them. That link isn't working for me.
    Quote Originally Posted by Green0
    CNC Mini-Lathe
    Jan 2006
    4396
    Question Chinese Mini Lathe
    Looks pretty good. But what type of control is that? Doesn't say if it has RS232 or USB interface. Beats the hell out of doing a lot of manual operations.
    I wonder if it has an optional programmable tail stock? You might be able to put a quick change tool post in it too.
    The Ad says it has a .0004 spindle accuracy.
    Toby D.
    Schwarzwald
    www.refractotech.com
    May 2005
    3920
    Interesting but what I'd like to see in a lathe this size is a spindle bored for 5C collets. It looks like they are real close dimension wise so this is a frustration.
    The other thing that bothers me is that a slant bed or somehting similar is needed to keep the swarf off the mechanics.
    Aug 2006
    51
    Smile
    I asked How Much : CK0620 CNC,USD $3850/SET FOB. They have some cool mills as well.
    http://www.made-in-china.com/showroo...CNC-Lathe.html
    I purchased the lathemaster 9 x 30 and was going to convert it to CNC. Have not even received the lathe and am already considering selling it and being a guinea pig on this machine. :idea:
    Apr 2005
    403
    jorge,
    That 9 X30 would be an excellent lathe to cnc, good and rigid.
    Ron
    Aug 2006
    51
    Quote Originally Posted by Ron111
    jorge,
    Ron
    Yeah ... I will probably stick with the original plan, it seems to fit my needs perfectly
