587,035 active members*
3,028 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Machine Accuracy Issues PRO4824 Mach3
Results 1 to 20 of 38
    Jan 2014
    29
    I thought I would turn to the forum for some further expert advise!
    I have a PRO4824/Nema23/mach3 Setup.
    I have an issue with the router not being very accurate.
    I believe it is a mach3 issue but I'll take any advise as to what to check.
    When I cut circular pockets say 3-1/2" or 2-1/4" in MDF or Acrylic the end result are holes with an OD that is undersized by .020 - .023 inches.
    Grooves or Slots also produce a width along the slot that is undersized by an almost similar amount.
    I consider this an un-acceptable amount.
    The perplexing issue is I have calibrated both X/Y axis to a distance of 4" & 5" with precision gage blocks, dial test indicator, dial indicator, calipers. Pointing out I'm doing this calibration with precision equipment. After the calibration is complete I return to the 0,0 point (Work Zero) of where the calibration started from and get a reading of being dead on at 0,0. One I jog move the axis is immediately inaccurate by .002-.005 thousands and grows somewhat larger as I move closer to the original calibration distance of the 4" or 5". The error occurs in single step and continuous mode. I figure things aren't quite right, proceed to re-calibrate mach3 for the correct steps repeating the process over again. This subsequent second time I have mach3 do a calibration move 5" in X or Y it moves perfectly that distance in calibration mode with no changes needing to be made to the motor steps.
    Cory at CNC Router parts mentioned earlier today to run in CV mode rather than exact mode, upon checking I'm already running in CV mode so thought I would switch to exact mode to see if it made a difference. It made no difference. Further I'm believing the CV Mode setting relates to circular or arc movements only and as noted above it is happening with both circular cuts and straight line movement.
    I've ruled this out as being a mechanical issue unless someone here thinks otherwise. I've gone over everything mechanical and find nothing out of order.
    Hoping someone here can offer some guidance on what the problem could be.
    Feb 2007
    4553
    Pete1961,
    Which stepper driver and breakout board are you using?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    You really should be calibrating to a larger distance than 5". For all you know your machine is perfect at 5", and could be off an inch at 24".
    Personally, I'd want the largest distance to be correct, and let any errors in the middle average themselves out, as there's not much you can do if your screws or rack are not consistent.
    Having said that, it's unlikely that the calibration is the issue with your circle size.
    If you cut a 6" pocket, is it off by the same amount?
    First thing I'd do is cut a single, shallow slot and measure the width, to see if the tool is the correct size.
    Then, cut two pockets, one climb cutting, and one conventional. See if there's a size difference. There usually will be.
    No, CV mode affects all movement, not just arcs. But it should have no effect on size compared to Exact Stop mode.
    Jan 2014
    29
    Gecko G540, CNCRP Supplied along with the Nema23 Motors they sell.
    Jan 2014
    29
    I would definitely like to calibrate over a much longer distance but not sure what machinists tool I can use that will get me out to 24" that doesn't cost a fortune! The distances everything is off at the moment I'm not even close to at 5" to believe it would improve at say 24".
    I did cut what was supposed to be a .750" X 24.00" Slot .563" Deep. Cut 3 of them and everyone was consistently off with the width being .810" X Depth being .610".
    I will do some more test cutting to see if the error's are proportional. They do somewhat but not completely. Interesting that everything comes up short and not to long.
    If the depth is wrong, then I'd say that most likely the Z axis steps/unit are wrong.
    Again, you need to cut some slots/pockets in the opposite direction to see if you're getting deflection.
    As for measuring long distances, clamp a tape measure to your table and put a pointed bit in thwe collet. Try to get the point at the edge of a mark on the tape. You should be able to get pretty close this way.
    Mar 2004
    636
    Silly question, but it your router bit new or has it been resharpened multiple times? Perhaps the bit is quite a bit undersize for the diameter you are using to program with? If you are using a 1/2" bit that has ben resharpened to .480, you now have a pocket that is .020 undersize. Doubt that is the problem, but worth a check.
    Dan
    Check out what I am working on at www.routerbitz.com!
    Jan 2014
    29
    Well for calibration purposes I use a drill rod in a precise bits collet. I did further checking this evening with a 12" electronic caliper and both the X and Y are out of callibration .006-.008". After multiple calibrations to just verify that my measuring is correct the results are the same. Changed the step pulse width and direction width and it had no effect. Diassembled the X Axis motor assembly from the rack to verify belt tension, pulley set screws, etc are tight and correct. They are all perfect. My initial belief of this being a mach3/G540/motor issue still holds. I find nothing mechanically wrong even rolled the X Axis on the V Con rails when I had the motor off and the movement is very smooth and noplay is felt in any of the mechanics of the gantry/carriage assembly.
    Jun 2007
    3734
    Put in a pointed tool.
    Move way from you reference to say1,1, using MDI, G1 X1 Y1 F200.
    Line up some mark on a ruler with the point, using a magnifying glass to get it perfect without doing any jogging.
    MDI X0 Y0
    then MDI X1 Y1. Same place with magnifying glass? Should be.
    now X2 Y2
    and X1 Y1. Should return to EXACTLY the mark.
    Do you have backlash? More than likely. A mechanical problem.
    Back to X0 Y0
    then X1 Y1. Surprised?
    If a cutter has runout it will certainly cut oversize.
    The only time to blame Mach3 is if you have backlash compensation on and set incorrectly or you are missing steps because motor tuning is not good.
    And it still not the fault of Mach3. Just the setup or the hardware.
    Does it have active high clock instead of active low or vice versa.
    Important to have have correct clock phase because direction must not change at same time as clock(edge)
    This is dependent on the driver setup and breakout configuration.
    Set up a loop program:
    X1 Y1
    X0 Y0
    X1 Y1
    X0 Y0
    X1 Y1
    X0 Y0
    X1 Y1
    X0 Y0
    X1 Y1
    X0 Y0
    X1 Y1
    X0 Y0
    X1 Y1
    Should be the same place.
    X2 Y2
    X1 Y1
    X2 Y2
    X1 Y1
    X2 Y2
    X1 Y1
    X2 Y2
    X1 Y1
    X2 Y2
    X1 Y1
    X2 Y2
    X1 Y1
    Same place? complete with error? Identify and fix the mechanical problem.
    You can certainly have backlash, and not 'feel' it.
    Cut some circles. Ar they PERFECTLY round or have flats (albeit small but usually visible) at the 90 degree points?
    Jan 2014
    29
    Could you explain the clock phase in a little more detail.
    I will run the test you mention tommorow. If there is backlash it seems odd the backlash is exactly the same in either the X or Y direction.
    I agree I definitely would not "feel" backlash by touching the machine.
    Jun 2007
    3734
    Clock phase?
    That information varies and is in the documentation for the controller.
    There will be some waveforms there, and it relates to this. Often can be the cause of lost steps.
    Jan 2014
    29
    This morning did some move similar to what you mention but only in the X direction rather than diagonally and the results to me anyway are odd. Tell me if this is backlash or something else.
    Moving away from 0,0
    X0,Y0 =0.000
    X1,Y0=.997
    X2,Y0=2.000
    X3,Y0=3.001
    X4,Y0=4.006
    X5,Y0=5.006
    X6,Y0=6.000
    X7,Y0=7.001
    X8,Y0=7.998
    X9,Y0=8.995
    X10,Y0=10.000
    X11,Y0=11.004
    X12,Y0=12.003
    Moving back to 0,0 as follows.
    X11,Y0=11.013
    X10,Y0=10.011
    X9,Y0=9.005
    X8,Y0=8.006
    X7,Y0=7.010
    X6,Y0=6.008
    X5,Y0=5.013
    X4,Y0=4.017
    X3,Y0=3.011
    X2,Y0=2.010
    X1,Y0=1.008
    X0,Y0=0.0
    Ran these inputs 3 times out and back, same sequence, same machine start point, same exact measurements every time.
    Ran another set of measurements from a different location on the table different results...
    X0,Y0=0.000
    X1,Y0=.989
    X2,Y0=1.978
    X3,Y0=2.974
    X4,Y0=3.970
    X5,Y0=4.965
    X6,Y0=5.970
    X7,Y0=6.977
    X8,Y0=7.976
    X9,Y0=8.982
    X10,Y0=9.988
    X11,Y0=10.989
    X12,Y0=11.996
    X11,Y0=10.999
    X10,Y0=9.998
    X9,Y0=8.994
    X8,Y0=7.986
    X7,Y0=6.986
    X6,Y0=5.983
    X5,Y0=4.976
    X4,Y0=3.982
    X3,Y0=2.989
    X2,Y0=1.989
    X1,Y0=1.000
    X0,Y0=0.011
    I have little doubt about my measurements being exact to .001"
    If there is backlash wouldn't it be more consistent with each 1" move?
    When I spoke to CNC Router Parts if I remember correctly there is virtually no backlash on the PRO rack unless someone can tell me otherwise.
    Anyone have any further thoughts on this issue?
    Looks to me like you have .01" of backlash, ±.001-.002
    Jan 2014
    29
    Thanks for the reply, I have gone into mach3 to account for backlash.
    Changing backlash settings has no effect on this problem tried .005", .008", & .010". Actually any of these numbers made no change at all.
    I re-checked so mechanical issues and cut the same part again same errors. Measuring circles shows them to be off further in the "Y" direction than the "X" direction. Cutting a square yields worse results. Square should be 4.406" and machine cuts to 4.353" on the "Y" Axis. Didn't check the "X".
    I'm going to also be scrutinizing the "Z" Axis as it appears to be cutting pockets deeper than my drawing shows them to be! They should be .193" machine is cutting them to .244"
    I wonder if anyone else using a cncrp router can advise if this is common?
    Feb 2004
    1086
    Hi Tom,
    Some of the issues could be related to the router not being trammed to the z axis. Have you surfaced your spoilboard yet? If not, this could also be impacting things. It's also possible that there is some looseness in the screws holding the angular contact bearings to the z-axis, and if so we can help you with this on Monday. All that being said, I'd hold off on dialing things in too much until you get the new parts you purchased, as you'll have to re-do a lot of it otherwise.
    Best regards,
    Ahren
    CNCRouterParts
    Jun 2007
    3734
    Where you do
    X0
    X1
    etc
    make sure you get to initial X0 from a X- location as it appears you change direction at the start of the test.
    Now you have figured the backlash is approx 0.01" set it going in a long loop..
    X0
    X0.01
    X0
    X0.01
    X0
    X0.01
    and see if you can find the lost travel.
    Maybe, with machine not moving, use a dial indicator and push/pull on axis by hand.
    Best to fix the mechanical problem before trying to get rid of it by tuning Mach3.
    Any backlash compensation causes all other axis but the compensated one to pause when there is a change in direction.
    This means the tool will rub shiny spots in the job, like at the quadrant points of circles.
    Jan 2014
    29
    I'm with you Ahren will wait till the new parts are here and then work on the mechanics.
    Thought I would get a better handle on the problem before the parts arrived.
    At least I will be learning something.
    Jul 2013
    608
    Quote Originally Posted by ahren View Post
    Hi Tom,
    Best regards,
    Ahren
    CNCRouterParts
    My machine was running baddddly... but I spend some long hours doing what Ahren mentioned and its now much better.
    I think your problem is different than mine, but I did too have some issues with accuracy. I don't know how to check for back lash or how to compransate for it but, one thing that helped make things run better at least for me (NEMA 34) was to turn down the acceleration from 30.
    Jan 2014
    29
    I'm in the process of partially dismantling mine because I'm going to upgrade some parts to make the gantry taller and stiffer. While i was working on it tonight I did find slop in the carriage for the Z Axis that was noticble once I removed the Z axis unit from the carriage. This may account for some or all of the issue. I don't believe I have much of a backlash problem if any. The measurements are not consistent enough for me to think it has that much backlash and only when I move certain times. Cutting circles are so far off it is most likely something else. I will re-evaluate everything very closely when I re-assemble everything. I have quite of measuring devices that were used previously and will be used again to check everything. I will add to this post once I reach that point.
    Jan 2014
    6
    Re: Machine Accuracy Issues PRO4824 Mach3
    my biggest accuracy problem was solved when i realized one or both of my x axis motors seemed to be "hiccupping".
    I pulled the drive components off, and I discovered that the tiny setscrews for the drive gears had spun out! two of them hit the floor and i lost one.
    I went to my machine shop and got some more, and i put them in with some blue loctite and made sure they were as tight as possible.
    After that, my accuracy increased tremendously!! I still have to do the Y axis, and anywhere else there are setscrews.
    Just thought I'd mention to check these setscrews.
  1. Replies: 7
    Last Post: 05-07-2014, 04:56 PM
  2. Replies: 54
    Last Post: 03-10-2014, 12:27 AM
  3. Accuracy Issues with Warthog and Mach3
    By Ed3XP in forum DIY CNC Router Table Machines
    Last Post: 12-17-2011, 10:56 PM
  4. Taig/Mach3 issues with accuracy
    By diamondback21 in forum Taig Mills / Lathes
    Last Post: 04-08-2009, 11:02 PM
  5. Accuracy issues
    By runninwild400 in forum Torchmate
    Last Post: 03-19-2009, 11:27 PM
