Originally Posted by
Makodean
Hey guys, I'm new here and I have been searching everywhere for some answers to my problems but can't seem to figure it out. I have a chinese 3020T (black control box) running on a Dell Optiplex GX620 with Windows XP Professional Version 2002 (32bit) set on EPP only mode and the port address is set to 378 in Bios and I can't get the darn stepper motors to work. When I turn the machine on the motors lock up and everything seems fine, I start the Mach3 program and hit the Tab button to enter the manual jogging mode and everything seems to be okay up until I hit one of the arrow keys on the screen or one of the keys on the keyboard and then my motors go loose the instant I touch either one of them and I have to turn off the machine, exist Mach3, start the machine back up and then enter Mach3 again just to do it all over again. Even though the steppers aren't moving, the DROs are moving on the screen. I have installed Mach3 as per the tutorial videos and believe the setting to be correct. I checked my cable to make sure it was a 1-1 cable via a continuity test. I have checked the voltage from my parallel port cable and I get 3.2 volts and 0 volts. Am I suppose to have 5 volts coming from the parallel port? I had read somewhere that the control box supplies the 5 volts to the stepper board. I do have 5 volts coming out of my probe plug that is attached to the same board. Anyhow, they adjust from 3.2v-0v as I jog the axis back and forth via keyboard keys and onscreen arrow keys. I have ran the driver test and everything looked good to my knowledge. I have the estop button working and even my touch probe responding in Mach3 diagnostics window. I have 5 leds lit up. I know for certain that 1 is for the estop and the other is for my probe so I'm assuming the other 3 are for the X,Y,Z axis..? Am I only suppose to have that amount of pins lit up? I don't know.
Okay, so now on to my settings, I have attached all the screen shots of my setting from my computer to my Mach3 settings below. In the motor outputs those are the numbers that came with the instructions for the machine. I have tried a few others that people have had tried but still no success in moving the steppers. I'm very confused at this point as to what could be my problem. I would greatly appreciate any help you guys could offer to get me up and running.
