586,744 active members*
6,007 visitors online*
    Aug 2005
    158
    CANDCNC LCTHC COULD THIS BE FAULTY?
    Bought a LCTHC from Viper Plasma and Can't get this thing to work. I hooked it up as the manual says and can't get the test mode to do anything. I removed all the wiring to the THC and ran power only to the unit and it behaves the same way. You go to run the test but it flickers where the ref Voltage should be. If I wait long enough I can get the ref voltage to display properly or if I disconnect the THC wire the Ref voltage shows up. What do you guys think?
    www.decalpro.ca
    Feb 2007
    966
    Hey, Did you ever get that big XY gantry setup and running ?
    Aug 2005
    158
    Hi Larry, I got it installed but there were a few setbacks. The VFD won't run on single phase and the table setup is less than ideal. I plan on rebuilding it this summer and finally put it to work. It's taking a huge amount of floor space but it ended up being a free machine (thanks again btw) so I can't complain.
    Dan
    www.decalpro.ca
    Mar 2011
    27
    Re: CANDCNC LCTHC COULD THIS BE FAULTY?
    I'm not sure what the Plasma Viper is (an individual? a company?) but CandCNC is the manufacturer. The guy who owns the company and engineered the products (I gather) posts on here as Torchead. The company's site is candcnc.com. See what they can tell you.
    --HC
  1. 4x6 Plasmabot 3.0 Build with Keling Controller & CandCNC LCTHC & Powermax 1250
    By Nacs Fab in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-31-2014, 03:49 PM
  2. Setting up LCTHC from candcnc.com - a few questions about install
    By MeisterWerks in forum Waterjet General Topics
    Last Post: 10-20-2012, 12:58 AM
  3. LCTHC/POWERMAX 65
    By foam27 in forum Waterjet General Topics
    Last Post: 02-18-2012, 06:17 PM
  4. CANDC.com LCTHC
    By diyengineer in forum Waterjet General Topics
    Last Post: 02-18-2012, 07:37 AM
  5. CandCNC LCTHC
    By Carter3 in forum Waterjet General Topics
    Last Post: 03-02-2011, 02:50 PM
