586,905 active members*
3,063 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Electronic lead screw (gear box), with Arduino for lathes
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    May 2006
    84
    Re: Electronic lead screw (gear box), with Arduino for lathes
    10 PCBs have arrived from China - lots of spares. Most of the eBay ordered components have arrived, I still need to order an encoder for the spindle.
    Pulleys for the encoder spindle have been machined and I now need to make up a mount for the encoder pulley, after I clean up the mill.
    While waiting for these bits and pieces, I think I've got a handle on the software but I'm sure to have lots of questions.
  2. #22
    Nov 2006
    Hello all. I have just order a board from Mr. Snowyskiesau. Wen the board gets to me I will start ordering the bits and pieces I will need. One question I have for Mr. Muck is have you gone any further with the program? I am new to Arduino. I have done cnc with g-code and I believe I am starting to understand your code. anyway I wanted to say hello and I hope you continue to contribute to this project.
  3. #23
    Feb 2007
    7
    Quote Originally Posted by MSNienke View Post
    O.K. After a few years of contemplating installing an ELS I have been pushed over the edge. I have a cheep Chineese lathe that "will do threading" with change gears. I have used lathes with change gears before, my dads old Atles, annoying but managable. But this useless thing 8 imperial threads and 8 metric, I have had to invent 2 additional pitches in the past. But the big killer, no thread dial. It is not just missing it was never there? I called the manufacturer and they said no "you do not use one, you engage the half nut only once, then drive the lathe forward for the cut and then drive it in reverse back to the start and then drive forward again for the next cut." Are you joking?.....No they were not. This means that when threading into a shoulder, which most of the time I am, I end up turning the spindle by hand, forward and back-forward and back. This time - 8 pieces, 4 female, and 4 male, 2 1/4-20 specialty thread.
    That is it. Ether the lathe goes or I get an ELS on it, but I am not going through this one more time. Most of what I do is one-sy two-sy or rework so the amount of overhead with full cnc is completely impractical.
    So I am ready to invest. Where do I go to get an ELS? Who should I be talking to? I have an Arduino and I used one in an EDM project about a year ago but I did not use the GRBL module so that will be new.
  4. #24
    Nov 2006
    Hello, geo.agun. Unfortunatly I do not believe there is anyplace to purchase this system complete. I do have a spare printed board for the project. I have just started attaching the bits ans pieces to my board, so I can not say that it is going to work. I have mostly converted the code to English, but it has not been tested yet. Pm me if you would like to talk about it more..
  5. #25
    Feb 2013
    Quote Originally Posted by geo.agun View Post
    While not an Arduino platform, here is a well researched and utilized ELS kit that has an active following: Electronic Lead Screw Main Page . See if what it offers is to your liking.There is a link to the Yahoo! discussion group, which for the last few months has had the creator toying with the idea of moving to various other embedded platforms (Beaglebone Black, Arduino, etc.)
  6. #26
    Nov 2015
    8
    I'm sorry to revive this old thread, but this is something I've been thinking about for a long time and searched for only to find very little (wrong google fu mostly.) I just now found this thread and wondered where people are with this?
    I considered taking this path when I discovered the state of the change gears in my lathe, but I opted to replace the gears. How have things worked out? Any wishes or misses over the time using it?
  7. #27
    Soldertraining Guest
    The Electronic lead screw is a simple way to automate your machinery and designed to enhance manual lathe operations. For further any other information I just refer one link Machine Tools: Electronic Leadscrew
  8. #28
    Jun 2019
    Dear sir, Have you completed this conversion to your lathe.?
    If so, was it any good?
    I am thinking of converting my AL340A lathe, but my grasp of electronics is very poor to say the least.
    I can do most things with electrical but I am soooo confused when it comes to electronics.
    If this conversion was successful for you could I indulge upon your expertise to help me with the electronics side of things?
  9. #29
    Oct 2020
    Hello
    I built this project but I have a problem with it ... The encoder on the board does not work and it does not show me the bar that is currently selected position. Is the code complete?
Page 2 of 2 12
  1. Electronic Lead Screw (ELS) Introduction.
    By jcdammeyer in forum CNC Machine Related Electronics
    Last Post: 05-03-2010, 03:45 PM
  2. Electronic Lead Screw, WABECO ELS 6000
    By MDA Precision in forum News Announcements
    Last Post: 12-11-2009, 09:41 PM
  3. Electronic lead screw
    By larry53 in forum CNC Machine Related Electronics
    Last Post: 10-25-2009, 06:09 PM
  4. Replies: 2
    Last Post: 09-15-2009, 02:06 PM
