586,475 active members*
3,494 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Central Machinery #33684 7" X 10" - how do i set up for a long taper??
    Feb 2014
    I am a newbie and just bought a used Central Machinery #33684 7" X 10" mini lathe. I have done multiple searches but not sure what the best way to cut a taper on a 5/16th shaft? I want to make about 50 pieces each time. I don't know the best method to achieve my taper - a 30 degree point. Please look the attached Drawing.
    Any help would be greatly appreciated! thanks
    Karl
    Nov 2005
    655
    Re: Central Machinery #33684 7" X 10" - how do i set up for a long taper??
    Cut bar stock to length
    use the compound slide........ rotate it to the angle needed to cut on the back side and reverse the spindle direction
    Walking is highly over-rated
  1. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  2. Replies: 6
    Last Post: 06-30-2012, 04:13 AM
  3. Replies: 1
    Last Post: 06-27-2012, 12:53 AM
