I'm getting back into machining after a roughly 8 year hiatus. I'm working on an aluminum project, having generated code with OneCNC.
I'm cutting a pocket that's rather deep using a long 3-flute 5/16" diameter 2" cutting length HSS end mill. I'm getting terrible inside wall surface finish. The program cuts layers 0.13" deep in .17" strips using conventional milling with Kool Mist, running 3000 RPM with a feed rate of 9 inches per minute.
Successive cuts appear to create a series of ledges, especially in radiused corners, where the end mill swings outward around the cut.
The end mill is in a collet chuck, since it wouldn't fit in a 3/8" shaft end mill holder. I'm not sure why because an identical end mill did fit.
The only thing that comes to mind is that for the length of end mill, I'm trying to take too big a cut. When the end mill bites into the aluminum, the end gets pushed away from the flute direction, outward into the the radiused corner.
Assuming I've described this problem adequately, does anyone have any ideas what might be causing this problem?
Thanks.
Paul
Showing radiused corner "ledges":
Attachment 225392
Showing generally uneven walls:
Attachment 225394
