586,161 active members*
3,396 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Good First CNC Mill?....1996 Haas VF-3
Results 1 to 15 of 15
    Nov 2013
    29
    I have been in the market for a CNC Mill for a year now and everything is 250+ miles away. I got lucky last week and via word of mouth, found a 1996 Haas VF-3 about 5 miles away from me. Here are the details:
    -Has been sitting for 3 years
    -Owner bought it as part of a set and uses the twin, has never powered this one on but is willing to hook it up for testing.
    -No Tooling Included
    -Machine is very dirty
    -Originally asking $25k but not actively advertising it. (it sits in the back of a large warehouse where nobody sees it, out of site, out of mind)
    -Control is in great condition (no button wear)
    Iam not sure where to start with an offer, he wants to sell it as-is, however, I told him that if i cant see it run and test it, the offer will be very low due to the risks involved...
    What do you all think? This is going to be my first VMC.
    What would you offer? I was thinking 18K if upon inspection it has no issues, or $13k AS-IS
    Thanks for your help!
    -Geoff
    -Geoff Warner
    VegasCarts.com & myVegasCarts.com
    Feb 2009
    6028
    If it powers up and moves around without much backlash or spindle noise, low 20s would be reasonable IMO.
    Sent from my G-Tab Quantum using Tapatalk
    Nov 2013
    29
    Re: Good First CNC Mill?....1996 Haas VF-3
    Is there an easy way to identify if the machine has Brushless Servos and Ridgid Tapping without turning it on?
    -Geoff Warner
    Jul 2005
    12177
    You may be able to get information from Haas if you call them with the machine serial number.
    If the keyboard does not indicate much use; as you say no button wear and the paint not worn off around the green button I would be tempted to go for a low offer As Is. Especially if all the way covers are nice and straight and there are no signs of things being thrown around inside the enclosure. I have many Haas machines and I find they are very reliable.
    Jun 2004
    511
    Its cheap and easy to reface a keyboard, not a good indicator. BTW
    Nov 2013
    29
    Seller will not take less than $20k and they did end up powering it on for me. Servos and Spindle work fine. Spindle is quiet.
    Serial # is 6875 (Built 2/96) and Haas doesn't keep build data past 10 years. Local HFO has no service records on it but I believe the machines were shipped in from the east coast so tracking down service records could be a pain.
    They seem to be selling for mid to low 20s so $20k seems fair ...
    -Geoff Warner
    Jan 2012
    13
    Geoff, there should be a build sheet taped to the inside cabinet door. It will tell you how the machine was configured.
    You can get into debug and see how many hours have been recorded however keep in mind you can reset these counters. Most don't not know how too but some do.
    The build sheet should tell you brush or brushless. Mine shows rigged tap too and the code to reset if necessary.
    Another way to tell brush/brushless is to look at the big axis/encoder cables coming out of the cabinet. If there's just one cable per axis it's brushless. Brush models have 2 cables side by side. Not sure what stickers a 96 had but I know HAAS was proud of the brushless models and I know 97/98s had brushless plastered on the front. So I'm thinking that one may not be. But the cabinet and cables would be the tale-tell
    Pic looks good though things get dirty just by shop dust floating around in a busy environment.
    Sep 2009
    93
    oh what a difference a year makes!!!
    Haas' got good in '97. i personally wouldn't touch one before then.
    hold out for a post '97 model. sometimes "more expensive" is cheaper in the long run.
    run away!
    Sep 2009
    93
    97 is the year they changed from what i call the "squirrel drive" to their very good vector drive.
    HUGE differrence
    Mar 2010
    1852
    I have a 97 and a 96 right next to each other. Both are brushless and both have Vector drive.
    Mike
    Sep 2009
    93
    ^^^^^good info, maybe they started shipping in 1996(?). does your vector drive 1996 model have squared-off sheet metal or the newer rounded?
    IIRC, the weak spindle drive was from Mitsubishi. check inside the control cabinet to confirm.
    Jan 2012
    13
    Believe 96 was the transitional year for the vector drive.
    Mike does your 96 have the Brushless Servos sticker on the front?
    Mar 2010
    1852
    Quote Originally Posted by mkd View Post
    Still square.
    - - - Updated - - -
    Quote Originally Posted by dresnerm View Post
    Yes, both have the stickers.
    Mike
    Nov 2013
    29
    I ended up passing on the VF3 and instead found a 98 Haas VF2 with 3600hours on it for $16,250
    What do you think?
    -Geoff Warner
    Nov 2013
    29
    The VF3 is still available so I might end up trading him for it...it would be nice to have another machine.
    More Pictures of it
    -Geoff Warner
  1. 1996 Haas VF-2 trouble shooting
    By Palmtreeguy in forum Haas Mills
    Last Post: 01-26-2012, 03:07 PM
  2. Haas VF3 1996 not finding Z-ref.
    By Nordic in forum Haas Mills
    Last Post: 10-29-2010, 06:16 PM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  4. Need Quickcode file for Haas HS1-RP 1996
    By Barney in forum Fanuc
    Last Post: 11-05-2008, 12:03 AM
  5. Pro's and con's buying 1996 HAAS VMC
    By djnbig in forum Haas Mills
    Last Post: 06-14-2008, 03:03 PM
