586,242 active members*
3,787 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Problem Subtracting Solid from solid Ver25
    Sep 2008
    34
    I am have an issue with this file. I am trying to subtract the Spiral Solid from the shaft solid. I select the shaft 1st, select the spiral 2nd, but it isn't subtracting the spiral from the shaft it is subtracting the shaft from the spiral. I want to end up with a spiral groove in the shaft. Can any one tell me what I am doing wrong?
    Tom
    Attached Files Attached Files
    Mar 2012
    1570
    What I would do is create only a section of your spiral, maybe 1 turn... Make that a solid and subtract.. If that works then undo and copy the spiral section down the shaft for number of turns needed. Then from there subtract each one...
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Sep 2008
    34
    Thanks Al, I will give it a try tomorrow. Any idea on why it won't work with the full spiral?
    "Sounds like a Personal Problem"
    Mar 2012
    1570
    My guess is you created a swept surface...
    And well it twists ....
    So you would need to do a skin. But you cant skin the whole spirle just one turn, same reason the twist.
  1. Subtracting a part from a solid
    By L98FIERO in forum BobCad-Cam
    Last Post: 09-10-2012, 12:28 AM
  2. Problem With Solid Fillet
    By missing link in forum BobCad-Cam
    Last Post: 03-28-2011, 06:02 PM
  3. problem usung array and solid difference
    By f32cpe in forum Rhino 3D
    Last Post: 07-28-2009, 10:37 PM
  4. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
