586,855 active members*
2,515 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics RW 15 gibs problem
Results 1 to 2 of 2
    I have a Milltronics RW15
    The table on Y is .035 out and .003 on X
    I can live with X but not Y out that much.
    What is the proper procedure to level the table.
    I've played with the gibs but couldn't get the table to level up.
    Is there supposed to be a plastic shims or guides on top of the gib rail that the table moves on?
    Sep 2010
    529
    Re: Milltronics RW 15 gibs problem
    I would check the headstock. If the gibs or turcite are damaged there, that would make the head go out of perpendicular to the table surface.
  1. DNC problem with milltronics centurion 6
    By gmenzies in forum Milltronics
    Last Post: 06-04-2021, 04:30 AM
  2. DNC problem with milltronics centurion 6
    By gmenzies in forum DNC Problems and Solutions
    Last Post: 06-04-2021, 03:58 AM
  3. Problem with a Milltronics VKM3 Centurion 6
    By WrenK in forum Milltronics
    Last Post: 10-12-2017, 12:16 AM
  4. Taper gibs vs Parallel gibs
    By Oldmanandhistoy in forum Linear and Rotary Motion
    Last Post: 09-09-2007, 01:25 AM
