586,352 active members*
3,651 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > Mikini/VFD post-conversion cutting videos
Page 3 of 4 1234
Results 41 to 60 of 67
  1. #41
    Aug 2010
    599
    Re: Mikini/VFD post-conversion cutting videos
    Dt
    warmachinellc.com
  2. #42
    Aug 2010
    599
    Dt
    warmachinellc.com
  3. #43
    Aug 2010
    599
    Sent from my SCH-I545 using Tapatalk
    warmachinellc.com
  4. #44
    Aug 2010
    599
    New video and blog write up. This one may be especially helpful to machinists because I detail an issue (especially in the blog write up) that I don't think I've ever read about before that can certainly lead to an elusive cause of chatter.
    Video:
    Blog post: AR15 High Rail Gasblock CNC Machining (10): chatter and interpolation | War Machine
  5. #45
    Aug 2010
    599
  6. #46
    Aug 2010
    599
  7. #47
    Aug 2010
    599
  8. #48
    Feb 2009
    2143
    Couple ideas for your issues on the 1/4" tool. Have you tried plunge milling just the corners, then doing the rest of that toolpath? You may also try drilling the corners before you take out the field in your first operation, and plunge mill the corner after drilling. That would have the part kept supported and vibration free when you do those 2 inside corners. Then go on with the rest of the operations as you have done in the video...
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  9. #49
    Aug 2010
    599
    Thanks for the suggestions Mike. That's exactly what I'm going to try.
    warmachinellc.com
  10. #50
    Aug 2010
    599
    I tried plunge milling the corners and it worked pretty well, much better actually. It was a little tiny bit chattery but I'll play with lowering the RPM a little.
  11. #51
    Feb 2009
    2143
    Did you try it in the same order as the video, or before you did the main material removal portion? Would also be best to use a tool with a small corner radius on it, not a sharp square edge...
  12. #52
    Aug 2010
    599
    Yes same as video. Roughed out first with the 3/8 rougher, then plunge milled the corners, then finished profiled with a small radius in the corners to avoid engaging the corners again. Worked great, just need to adjust the rpm down a little.
    This endmill has sharp corners but its replacement has a corner radius. I agree that should work better.
    warmachinellc.com
  13. #53
    Aug 2010
    599
  14. #54
    Aug 2010
    599
    New installment. A lot of useful info for aspiring machinists, inventors, product developers, and numb nuts (like myself) in this blog post from hard fought and won experience.
    Blog post: AR15 High Rail Gasblock CNC Machining (14): finalizing side ops | War Machine
    warmachinellc.com
  15. #55
    Aug 2010
    599
    Latest video is out and a significant milestone has been reached!
    Blog post: AR15 High Rail Gasblock CNC Machining (15): first test production run | War Machine
    warmachinellc.com
  16. #56
    Feb 2009
    2143
    Looks great! Congrats on the bio-machine - I didn't see that option in the list when I got my Mikini!
  17. #57
    Aug 2010
    599
    Ha! It didn't come with the machine it was a parameter setting in the VFD I think. The Mikini just came standard with bio-hazard for a spindle driver. Lol.
    warmachinellc.com
  18. #58
    Aug 2010
    599
    New video up: Soft jaws
    Blog Post:
    http://www.warmachinellc.com/ar15-hi...-off-back-tab/
    warmachinellc.com
  19. #59
    Aug 2010
    599
    Next video in the series is out.
    Blog: http://www.warmachinellc.com/ar15-hi...arrel-pinning/
    warmachinellc.com
  20. #60
    Feb 2009
    2143
    Watching at work with sound off. Is that a Harbor Freight bandsaw? Model #? Looks quite capable at cutting thick steel...
    BTW, the part looks GREAT! Must be satisfying to see the end result after so much hard work. Hope you do well in sales of these guys!
Page 3 of 4 1234
  1. Mikini/VFD conversion SWATH
    By SWATH in forum Mikinimech
    Last Post: 06-19-2014, 01:28 AM
  2. Replies: 90
    Last Post: 05-10-2012, 02:18 PM
  3. Sherline Mill CNC Conversion Videos
    By panofish in forum Benchtop Machines
    Last Post: 04-11-2012, 02:40 PM
  4. Replies: 0
    Last Post: 09-21-2009, 10:26 PM
  5. Sherline cnc conversion videos
    By panofish in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-18-2009, 01:11 AM
