586,359 active members*
3,421 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > Mikini/VFD post-conversion cutting videos
Page 2 of 4 1234
Results 21 to 40 of 67
  1. #21
    Sep 2010
    529
    Re: Mikini/VFD post-conversion cutting videos
    Just as a second thought, you could always diamond the smaller locating pins on your fixture, they don't even have to be diamond shaped, you can just mill flats on two sides so the pin only locates in the axis it needs to.
    I've just done a lot of production work and you want your fixturing to be as easy and quick to use as possible.... like I don't know how you expect to get at the bolts for the parts in the rear? Take the fixture out of the machine? I think I would have investigated a fourth axis and used a tombstone for the parts.....
  2. #22
    Aug 2010
    599
    Thanks Brian that's very good info. I did not know about the diamond pin theory. I guess since I already made the fixture, if it becomes an issue I can still make the small round boss a diamond shape and see how that works.
  3. #23
    Aug 2010
    599
    Latest installment in the series. Finally some 3D profile machining using the new fixture plate!
    Blog article: AR15 High Rail Gasblock CNC Machining (7): side gutting and 3D profiling | War Machine
    AR15 High Rail Gasblock: (pt.7) Side gutting and 3D profiling
  4. #24
    Aug 2010
    599
    Here is the latest episode. Maybe some of you machinists can offer some advice on a few issues I've been having. They are detailed in the blog post here:
    Blog Post: AR15 High Rail Gasblock CNC Machining (8): roughing, finishing, and bayonet test cuts | War Machine
  5. #25
    Sep 2010
    529
    For your center bore, what size hole prior to milling the .750 stepped bore? What sort of tolerance on the bore do you need, any further machining to it afterwards? If the clearance hole is already in there, and you just need a .750 hole, I would buy a 3/4" end mill with a small corner radius ground on it. skip the roughing and just plunge feed it down there. You might have to peck to clear chips, but it will act just about like a reamer and has a whole lot more room in the flutes to evacuate chips, especially in a deep hole like that.
    For your drilling issues, use your high speed peck, usually a G73 to a depth you feel comfortable with, then change to G83 (full retract) and finish the hole from there. Some machine (lathes in particular) have a G-code that will allow variable depth pecking, I can't remember the G-code, but you can use percentages of the hole depth or distances and have then decrease per peck to a minimum peck amount which it will then use to the bottom of the hole.
    Your last issue on the outside, with the end mill springing away, or the part pushing away.... not sure of your radii, but if by chance it was the same as that .750 EM you could use on the i.d., you could go to position and plunge in Z only and get a lot less deflection.
    I'm doing a part at the moment that's 1.25" thick aluminum with a odd shaped inside "window" thru the part and I found roughing the part using the spiral pass.... think it's 5 loops around the interior with a tad over .25 change in Z depth each pass... kind of like thread milling, does a much better job of keeping some of the sharper corners with the same amount of final pass stock. I spiral mill at .002" material left, then make one loop around the part at full depth a slightly reduced feed rate to do the final finishing.
    Just a few ideas for you.....
  6. #26
    Aug 2010
    599
    Thanks very much Brian! The drilled hole is 14mm then I rough it to approximately 0.742 or so with a 1/4 step at the bottom. Tolerance I would say is -0.0005, +0.001 of the finished bore. I thought about using an endmill but a 3/4 reamer is a heck of a lot cheaper than an 3/4 endmill. My other objection is that I'm paranoid about chipping the flutes plunge cutting with an expensive endmill. I mean a Lakeshorecarbide 3/4 endmill is over $160. I just bought a 3/4 reamer for $60. I need to keep replacements costs in mind.
    Are you saying drill the 14mm (0.5512) hole then plunge mill the final bore with the 3/4 endmill and eliminate the roughing? Isn't that hard on the flute tips even being radiused? That suddenly seems like an attractive option despite my paranoia about plunging endmills, especially $160 ones. It just doesn't seem that endmill would last that long with all the cutting on the tips. Am I wrong?
    I'll check into optimizing the drill cycle again later but that is kind of what I thought about doing. G73 for like the first half of the hole, then G83 for the bottom half. That's not a huge issue though.
    My main issues in order of importance are:
    1. getting a nice finished accurate bore
    2. eliminating the chatter from the roughing ops to extend tool life
    3. getting a really nice finish around the outside in as few passes as possible and without chatter.
  7. #27
    Sep 2010
    529
    I would try a HSS end mill first and see how it does.... I probably have a half dozen rolling around in my roll away. But I suspect you wouldn't have any trouble with corner chipping and you should be able to hold that size as long as the tool doesn't runout in your holders. As for longevity, you making thousands? Or hundreds? Or 40-50 pieces? Even HSS in this situation should give you probably over 100 pieces. Oh, you can hand stone a slight radius or chamfer on the leading corner of the EM if all you have is sharp cornered.
    Using an EM will give you as nice or nicer of a finish than the reamer, now if you have trouble holding size, you could always use a reground EM that was say .740" and then ream to the .750", would still most likely beat the pants off interpolating the hole with a smaller end mill.
    Eliminating chatter is a tricky situation, you want smaller end mills than your tightest radii, but then too small and they tend to chatter and scream. That was part of the reason for my suggestion of plunging rather than side cutting. If you could get adequate size and finish in the radii, then have your finish end mill that profiles just skip across that internal radius, you can blend into it and out of it, especially as you say you will sand blast after machining.
  8. #28
    Sep 2010
    529
    As a follow up with more information, I just got this email in my inbox about an article concerning Helical interpolation vs. rough boring on holes, might prove an interesting read:
    Manufacturing Engineering - Tool Time for Fracking
  9. #29
    Aug 2010
    599
    Thanks for the article Brian. I'm still looking into the plunge milling angle. I am fascinated with this now but still have some reservations coming from inexperience.
    Here are some of my worries:
    1. boring the hole oversized with a 3/4 nominal endmill. A regrind could solve that issue but where is a good place to buy regrinds? I might ask Carl at Lakeshorecarbide about making a 3/4 pre-ream sized endmill.
    2. It sounds like it could be much slower than roughing interpolation. What speeds do you suggest doing the plunging with?
    3. tool llife (i.e. the flute tips) since this is for my flagship product I will be making these exclusively for awhile. That's why I'm trying to get everything dialed in as best as I can from the beginning.
    If I were to use an endmill what should I use? 2 flute, 4 flute, etc. What is a good HSS endmill? I only have experience with carbide. Is it true that carbide endmills are all slightly undersized?
  10. #30
    Sep 2010
    529
    Lakeshore already makes pre-ream end mills: METRIC PRE-REAM ENDMILL
    Rpm is whatever SFPM you are currently using, feed per tooth could be upwards of .005" per rev as you aren't taking that much material and no full length side loading. Program it that way and run your simulation and see if it's faster or slower... always been faster in my experience.
    Tool life, well, like I said, how many do you need to run? If you can get a HSS or Cobalt EM fro $40 and it will run 100 pcs. and a carbide is $160, you better be able to get 400 out of the carbide, although there is something to be said for the extra rpm you will be able to run with carbide. No end mills are "slightly undersize", they are made to size within the tolerances the grinder has, usually about .0002". Good HSS end mills, Putnam, Weldon, Melin, OSG and the list goes on, just stay away from generic stuff that most likely comes from China.
    Oh, I would go with 4 flutes as you double the ipm of the 2 flute.... so it will be twice as fast and still should have plenty of room for chip clearance. I have a 3/4" HSS Putnam in my rollaway, it's a 2fl and I'd need to know depth of hole, but I could send it to you so you can try out the situation.... I got it when I paid $100 for a whole box full of end mills at a yard sale.
  11. #31
    Aug 2010
    599
    They do but I didn't see any 3/4 ones. I got the reamer today but it will be at least next week before I can try it. The bore needs to go down about 2.25 or so. I was looking to order one from Enco but I realized that I just missed the 20% off + free shipping promo by one day damn it. I very much appreciate the generous offer to try your endmill but I suppose I should just buy one because I'm sure I could find another use for it even if the plunging doesn't work out.
  12. #32
    Feb 2009
    2143
    I SO need to upgrade my spindle... I stall on EVERY use of a 1/2" tool even in aluminum. I would not even dream of trying a 3/4" in steel!!! I had a solution "on the way" from SkyfireCNC, but he seems to have vaporized, so back to the search for a "simple, effective, available" solution...
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  13. #33
    Sep 2010
    529
    Well, Enco has 13% off today, and I'm sure the free shipping code is still there for the month. Better than that, I have a slightly used 3" length 2fl that somebody modified the shank slightly on.... if you want a freebie to try out, email me your info at blamb11 at cox dot net and I'll mail it to you to try out. Going to try to add a picture of it...
  14. #34
    Aug 2010
    599
    Ok Brian I'll try the endmill and put it in one of my next videos! Thanks a lot! Email sent.
  15. #35
    Aug 2010
    599
    Hey Mike,
    Yeah I vaguely remember back when my spindle sucked...it seemed like as if a bad dream. Like I repressed those memories with selective amnesia the way a victim of traumatic abuse might. Details of that time period still only come out under deep hypnosis. Now when I watch the spindle cut I breath a sigh of relief and tell myself it was all just a horrible dream. I still have a little PTSD from it though like how my heart sinks when I inadvertently and unknowingly hit a soft limit and the spindle suddenly stops. Then I realize what happened and again breath a sigh of relief while I mummer to myself "it's OK it's OK that is what is supposed to happen".
    Sorry to hear about the Skyfire thing. I bet Defeng will get his business straightened out one day, but how long to wait is the question. You can tell he's put a lot of effort into it but is charging up hill.
    In the meantime if you are ready to pull the trigger on the VFD conversion I'll help anyway I can. Under normal circumstances I would offer to come over and help since I think you are only a couple of hours from me if that but my family obligations are too great right now (taking care of a toddler full-time and the wife is about to drop another). I have figured out how to do a seemless conversion from the existing BLDC to a VFD. I even have a spare REX84 card V1.0 laying around I could put together for you for no charge if you wanted. Which works fine and is what I'm still using. If you wanted the upgraded and improved V2.0 card I would have to send off to have some printed so there would be a small cost. I can give you a parts list of every thing you would need like VFD, motor, cabling, etc. and I can even send you some of the left over materials that I have extras of like connectors and Cat7 cabling and stuff. I'll also send you the 3D model of the motor mount but it is designed around a certain size motor (145TC frame C-face). I never got around to updating the model with the very slight changes I made to it but I can easily tell you what I changed and you can update them in solidworks. The changes were really just dimensional tolerance issues like a bolt hole being a little too tight or something.
    I'm convinced the 2HP vector duty motor I'm using is massively powerful for this machine probably even overkill. I haven't even come close to stalling it with the kind of cuts this machine can handle. This motor easily exceeds the rigidity of the machine (which I even think is pretty good). Keep in mind the vector duty motor and this particular VFD while rated for 2HP can actually cut at 4HP (200% over drive capacity) under load for a period of time before starting to get too hot with excess current so the few times when you might "accidentally" exceed a 2HP cut it won't just crap out and stall, it will do the cut albeit at higher than continuously rated for current. If you do that for too long you will just get a thermal alarm stating the motor is getting hot, under normal cutting loads it is just slightly warm to the touch.
    I always get excited about a potential Mikini makeover.
  16. #36
    Feb 2009
    2143
    If you don't mind sending info to me that would be great. I would like to see what would be involved. I have too many projects going on right now (building a house, so the associated move. Motor swap on 1 car, need to repair radiator leak on second car, need to install suspension on the truck, travelling out of the country about 50% on business travel, etc.), so I don't want to dive in to a "more than a day long" conversion right now. That's why Defeng's solution was so tempting - I think it would truly be "plug and play" (at least after the first person figured out the right settings, etc.). But I am thinking that road is now a dead end...
  17. #37
    Aug 2010
    599
    If you had all the materials and knew exactly what to do I think you could do it in a day, maybe two. I'll work on putting together a list of what I used and a writeup later tonight or tomorrow maybe and you can decide if it's something you want to jump into right now. Probably the first thing I would do is machine the new motor mount since this will not take the machine out of commission and order the main things like motor and VFD.
    I'll start a new thread for it.
  18. #38
    Aug 2010
    599
    Dt
    warmachinellc.com
  19. #39
    Aug 2010
    599
    New video up. Thanks again Brian for the endmill and I apologize profusely in advance for...well watch the video and you'll see.
    Blog Post: https://warmachinellc.com/ar15-high-...ing-main-bore/
    Video:
  20. #40
    Aug 2010
    599
    dt
    warmachinellc.com
Page 2 of 4 1234
  1. Mikini/VFD conversion SWATH
    By SWATH in forum Mikinimech
    Last Post: 06-19-2014, 01:28 AM
  2. Replies: 90
    Last Post: 05-10-2012, 02:18 PM
  3. Sherline Mill CNC Conversion Videos
    By panofish in forum Benchtop Machines
    Last Post: 04-11-2012, 02:40 PM
  4. Replies: 0
    Last Post: 09-21-2009, 10:26 PM
  5. Sherline cnc conversion videos
    By panofish in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-18-2009, 01:11 AM
