586,931 active members*
3,092 visitors online*
    Feb 2014
    Hitachi Seiki VS 60 Fanuc 18
    Hey guys, my tool changer is about an inch off of where it should be when in position. I'm not sure if the operator crashed the ATC while indexing or what. Anyway, I need to manually reset the zero or home position for the ATC. Does anyone know of the parameter that I can set for the ATC with a Fanuc 18?
    Sep 2010
    125
    you only have to turn by hand your magazine still the pot number one is in transfert position and then only to set parameter 1815 (apz) of the 4th axis in fanuc side To 0 , then to 1 .that's all
    Dec 2009
    542
    Hello,
    let me know if you still need help.
    John
  1. Hitachi Seiki 4NE11 Fanuc 6TB
    By Leblondmakino in forum Fanuc
    Last Post: 11-08-2014, 12:22 PM
  2. Hitachi Seiki VA 35 mill w/ 6m fanuc
    By rdstillw in forum DNC Problems and Solutions
    Last Post: 12-27-2013, 05:28 PM
  3. Hitachi Seiki w/ Fanuc 18 C
    By jumpstart in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2010, 09:20 PM
  4. Hitachi Seiki Fanuc 11M Parameters
    By diegojulio in forum Vertical Mill, Lathe Project Log
    Last Post: 03-03-2009, 12:33 AM
  5. HITACHI SEIKI / Fanuc 11m
    By mn12mike in forum Fanuc
    Last Post: 12-14-2008, 06:06 PM
