I may have previously noted how noisy my Y-axis movement is. It sounds like an angry cement mixer when moving Y+ (table moving toward me), but is fairly quiet going back in the Y- direction. From reading everything, everywhere I can, I looks like thrust bearings need replacing. I have seen in a previous post from Bloke about the bearing numbers, but I have not found any diagram or step-by-step of how to get to them. I removed the cover plate in front of the Y servo at the front of the mill, but don't see any thrust bearings there, unless I don't know what to look for. Does the table have to be removed to get to them? Thanks in advance for all the help found here.
