The MX3660 appears to have the analogue output required.
The actual points for the +12v, common and analogue in are common or 0v is either F-v or I2, these are 12v com, the +12v can be picked up either at the (live) end of the max rpm pot or a couple of other places on the board.
If you pick the power up from the P1 and P3 they are 'tailored' by the max and min speed pots.
So if using these, they should be turned to Min resistance.
Al.
