586,384 active members*
3,685 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 50 Pin- SCSI HDD drive of capacity 45MB GE Fanuc Series 150M
    Dec 2006
    310
    Dear Sirs
    We have got a Gleason(Phoenix) Gear Cutting Machine with 50 Pin- SCSI HDD drive of capacity 45MB
    This machine works with Flex operating system and machine is working fine
    Please let us know on how to take ghost image of this harddisk
    Pl let us know about the possibility of connecting this harddisk to a windows PC with Xp so that we can recognsie this SCSI HDD and try to take image using Norton Ghost
    Best Regards,
    Aug 2011
    2517
    its very simple. plug in a SCSI controller that is compatible with your type of HDD (SCSI 1/SCSI 2/ SCSI Ultra, SCSI Wide etc etc), plug in the HDD, power on the PC. Once booted install the SCSI drivers. Reboot. Then image the drive using Ghost or some other software.
    Dec 2006
    310
    Dear Sir
    V could locate a vendor who has got SCSI controller and he told he would be able to get a new SCS 1 - HDD of capacity 45MB (upto 250MB)
    He wud connect exisiting harddisk (which uses FlexOS operating system which is similar to DOS FLEXOS/ MMC software) with his SCSI controller and take image, connect new SCS 1 - HDD of capacity 45MB (upto 250MB) and burn the image of exisiting harddisk
    Kindly confirm with this whether we will be able to connect new harddisk on to the machine and start using it straighaway or we need to load Flex OS and Machine software
    Best Regards,
    M. Rishikesh
    Aug 2011
    2517
    if you image the drive exactly on to an identical HDD you just plug it into the CNC machine and it works as before.
    To image it you only need a common PC with a common SCSI controller and some imaging software. The task is very simple.
  1. Replies: 10
    Last Post: 01-16-2020, 08:45 AM
  2. GE Fanuc Series 150M - Harddisk
    By M.RISHIKESH in forum Fanuc
    Last Post: 04-19-2013, 02:03 PM
  3. GE Fanuc Series 150M - Harddisk
    Last Post: 04-18-2013, 12:48 PM
  4. Replies: 2
    Last Post: 10-16-2009, 01:22 PM
  5. GE FANUC SERIES 150M
    Last Post: 10-06-2009, 01:56 PM
