586,281 active members*
3,707 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Inputing CAD drawing into alphacam
Results 1 to 9 of 9
    Feb 2014
    1
    Hi All,
    new here and 2 months old on CNC. I have AutoCAd experience though.
    I'm having trouble with manipulating the drawing after I have inputed a CAD dwg into my alphacam drawing. The Cad file was saved down to 2004.
    I can input the drawing fine but once into my alphacam drawing space i lose the ortho function, the mirror function brings up an option window which it usually doesn't, and the autosnap function doesnt work like it should as well. These are just a few examples.
    I've tried exploding it and then joining it, but it won't let me select any of it to explode.
    Any suggestions?
    Thank you in advance,
    Todd
    May 2011
    108
    Hi - if you attach Your DXF-file - and the AlphaCAM file, then it's much easier, to give You an answer - sure, it's a small issue :-)
    Mar 2014
    6
    Need to move it to to flatland.
    Oct 2013
    109
    Re: Inputing CAD drawing into alphacam
    Like RSmitty says. Move it to flat land. Or check what plane you are on. And put it back in to 2D drawing mode rather than 3D or Auto.
    Dec 2008
    10
    Use the Project 3D to 2D function to remove the extra workplanes created by the autocad software. This is very common when inputting autocad drawn items into Alphacam
    Steve Searle, Alphacam Training Manager Alphacam 2014 R2
    Vero Global Support Portal http://customers.verosoftware.com/
    Nov 2013
    152
    Hi all
    A note on moving plains to flat land, when I have tried this the geometry dissappears completely although it shows on the layers as still being present!! Any suggestions anyone ?
    May 2011
    108
    Quote Originally Posted by Routerfiend View Post
    Hi all
    Try to attach the drawing, You have trouble with - certainly there is a good explanation to this matter
    Nov 2013
    152
    It won`t let me upload an ard. files sorry. It`s the first time i`ve tried .A new quirk though, this time when you move it into flat land the geometry shifts position in x by about 5 mm ??? Although it remains visible I can`t repeat the dissappeaing act that sometimes happens. But then that`s what make alphacam so exciting , you never know what it`ll throw up next
    Oct 2013
    109
    Different planes have different origins. This is the point of them. Your geometry is moving when you move it to flat land because it has a different origin. Zero your origins. Or use the project 3D to 2D function.
  1. Replies: 1
    Last Post: 08-02-2012, 06:17 PM
  2. AlphaCAM 00 and AlphaCAM V5 - same postprocessor
    By Ziyan in forum CNC Machining Centers
    Last Post: 10-10-2011, 12:59 AM
  3. Replies: 13
    Last Post: 10-02-2009, 04:32 AM
  4. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
  5. Alphacam
    By zoltan in forum Uncategorised CAM Discussion
    Last Post: 03-21-2007, 02:38 PM
