586,708 active members*
2,435 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > STL Slicer Software by LHR Technologies Released
    Mar 2011
    29
    Attachment 223292
    STL Slicer Software Released
    Make it 3D.
    Make it manageable.
    Make it machinable.
    Make it a reality.
    Whether you are using a CNC or a 3D printer, with Slicer, you can slice your 3d models into manageable sized pieces to fit your machine. The pieces can then be created and assembled to bring your digital model to reality.
    Stop being confined by the output capacity of your machine. Whether it is a 3D printer or CNC, size usually matters. Well, not anymore. With Slicer, you can scale your model to any size and slice into manageable-sized pieces that your machine can output.
    Slicer has versatile slicing capabilities. You can rotate your model any direction and select any angle or depth. It allows you to remove areas and even reattach them.
    Visit us at STL Slicer
    or on Facebook at https://www.facebook.com/stlslicer
    Sales & Marketing Manager for LHR Technologies, the makers of CarveWright.
    Jan 2007
    1795
    I had always problem to handling stl files..
    I saw this program long time ago.. this stl slicer was 300 dollar.. now I see it is only 200
    do you have link to download a demo?
    eventually I used the free netfab what also could slice and repair open edges or closing up meshes..
    recently just found meshmixer by autodesk..
    beyond slicing stl files it can sculpt
    or remesh large stl files..
    I just broke down to parts a 200 mb sized walking figure..
    works like a dream, just like anything by autodesk..
    by the way meshmixer is free..
    Sandbox | Autodesk 123D
    Mar 2011
    29
    Download free demo at www.stlslicer.com. View tutorials there, too.
    Jan 2007
    1795
    thank you for the download link..
    very interesting program..
    I made some test with a figure I created in a subd modeler..
    the aligning functions I think could have input field for degrees, not only 90 deg options.. the cube that shows the actual axises is great..
    the known universal manipulator would be a great addition..
    well.. the readme.txt saying subdividing.. I was in the faith a low poly mesh can be subdivided..
    I also missing the feature that popular formats, beside stl can not be imported.. like 3ds and obj..
    if you were interesting, accutrans licensing for 100 a dll that makes the perfect conversion between meshformats..
    http://www.micromouse.ca/pricing.html
    this dll file is for converting between many meshformat.. forth n back
    many model available from net in 3ds and obj format..
    obj format as can contain quads can be subdivided well, to smoothing out a low poly mesh..
    the attached picture shows with subdividing you get a smooth desired surface..
    beside planecuts I miss the parting function where I could separate limbs example from a complex figure.. making simpler to fabricating a project like this..
    with this example, it would be great to separate the shield and arms..
    the separated parts, already good for slicing..
    good thing, that separated shells be closed separatedly..
  1. Web Machinist 4.6 Software Just Released
    By MetalZilla in forum News Announcements
    Last Post: 08-22-2013, 09:33 PM
  2. Nesting software NestLeader2.6 released
    By Nestprofessor in forum News Announcements
    Last Post: 10-17-2012, 03:28 AM
  3. CNCDuDeZ FREE USB Software released
    By CLaNZeR in forum News Announcements
    Last Post: 05-22-2010, 09:33 AM
  4. New LetterCAM Software Released!
    By WarrenW in forum News Announcements
    Last Post: 06-24-2008, 03:16 AM
