Hello all....I am looking at some used Mazak mills and some have the M32A control and some have M32B. Does anyone know what the differences are between the two?
As far as I know, from an operator's point of view you won't see any difference. So for your M32 controls you should instead look out for what options have been activated on the machines that interest you (eg: helical interpolation, more memory, etc.).
Cheers.
A guy at a Mazak dealer told me the only difference as far as he knew was the M32A had a color Monitor and the M32B had Monochrome.
As I said, you should be checking out for your control's options that are activated rather than whether it is a M32A or M32B if you are to make this a factor in your decision to purchase or not at given prices.
Hi all,
I have a Milling machine Mazak M32A. Magnescale of X-axis has broken. I want to take it away but I don't know how to setup servo parameter???
Thank you!
I would be replacing the broken scale. More accurate than encoders
Regards Bob
