Hi Shenhui and fixtureman
I've received my laser power meter today but it says I need to make the laser shine on it for 29.1 seconds then take a reading 30 seconds later.
Any ideas how you set the laser to fire for an exact amount of time? I can't see it in the settings or the manual.
Also Fixtureman in another post I think you suggested I try to burn the rubber at the laser head rather than the final cutting head to bypass the mirrors etc.
When I tried this I got quite a large diameter beam spot from the laser and while it was trying to burn through the rubber it just ended up sort of heating the rubber up and not really cutting through it.
I left it burning for a few seconds but it didn't get through. Maybe my laser tube is a dud or maybe it isn't concentrated enough at the start before it passes through the mirrors and then hits the lens.
incidentally just by timing the firing using a stopwatch I got approx. 27W at the laser tube and the cutting head with the lens removed. When I put the lens in it reads about 12W but the instructions say to measure the unfocused beam.
Note: The power meter won't adjust back to zero no matter how far I turn the set to zero screw. (can I ever buy anything online that just works out of the box?!) so I had to guestimate the readings a bit. The needle rests at about -15W (ie 15W below 0)
