hello
long time ago I tried to play with MDF
I made a "sandwich design", see here:
CNC Hobby Mill - Z-axis - first run - YouTube
Unfortunately I had a HDD crash and I don't have the CAD files
The good news is the results which was better than expected
The sandwich design is really strong and will be a good start for a hobbist
The linear bushings was "burried" inside the MDF sandwich. Same for the ACME ballnut.
All MDF sheets are fixed and tighten together by the black screws. The nuts are also burried inside
But, as a personal opinion, don't go for a MDF machine is you want to keep it (and use it) for long time
A little bit better will be the plywood and even better look for aluminum design.
Good luck,
Seb
HTM.Ro - Hobby Tools Manufacturing
