Hello, I'm new to cnczone and am hoping that I can get an answer to a problem I'm having with my new Gecko 540.
I have it hooked up to a PC running Mach3. After quite a bit of messing around with configuring Mach3 I have it to the point that the steppers drive the slides just as the program tells them to. Outputs 1 and 2 however aren't doing so well. I hope to turn on a laser with an M03 and turn on shielding gas with M08. When the program runs, I measure voltages of 8 and 16 volts at terminals 5 and 6. My supply is 42 volts. Isn't that what I should be getting between the outputs and the positive terminal of the supply? When I connect a relay the voltage reading is zero and the relay does nothing at all.
Am I missing something?
