Hi All, I have been lurking around the forums for quite a while now reading various build threads and trying to decide what I would like in a CNC machine. I have came up with a rudimentary design for the table. I am going to share it with you and hope to get some constructive feed back on where it might be improved.
I dont want to get rid of the drawers or the wood storage in behind the drawers, that is why there is a lot of bracing on the interior in hope to compensate for the lack of bracing on the exterior.
It will be 6 months plus before i can start building it.
Goals for the CNC.
This is just going to be my hobby machine, i have no expectation to earn with it.
Mostly woodworking(furniture, boxes, signage), maybe some aluminum but not a design requirement.
be self contained and mobile(small shop), drawers to hold tooling and electronics, small section in the back to hold materials. act as an assemble table for the items that i create with it.
Specs:
Work area ~30" x 50" 6" Z travel.
The frame is a combination of 2x4 and 2x2 1/8th " steel tube welded.
Spoil board is a MDF Torsion box.
Welding method is going to be distributed tacking to minimize distortion.
the Bearings are CNCRP bearing trucks on CRS
X axis will be dual drive.
Undecided/not yet designed.
motion is most likely going to be R&P for X&Y and a Chinese ball screw(1605 or 2005) for z
Gantry - after reading all the fine analysis from DMalicky, the Gantry beam is is probably going to be 6X6 1/8th wall steel beam
Spindle - going to start out with a wood working router i have currently and then update to a Chinese spindle at a later date.
Motors/electronics. I was waiting until had had flushed out the design for the Gantry before i made up my mind, but i am leaning towards a G540 and some Nema 23 320oz low inductance steppers w 48V regulated supply.
So....... Where can i improve?
