586,127 active members*
3,305 visitors online*
IndustryArena Forum > CAM Software > UG NX > Posting half the tool radius for cutter comp instead of zero for tool wear.
    Nov 2005
    244
    All of our Nx 8.5 programs are posted with a zero value when using cutter comp.
    My situation is we have legacy .NC programs that have the cutter comp. value half of the tool radius. We no longer have the Cam file associated with the .NC file. I have to make some changes and improvements to the program but not the whole job.
    How do I post out my cutter comp. values for half of the radius?
    Thank You
    Apr 2012
    40
    Can you post some sample code in the format that you are wanting so that I can see the difference.
    146
    ON the tool dialog you can set the tracking point of the tool. This can control if the tool output is from the centerline of the tool or from the tool radius. I would recommend reading the help docs on this. There is an example of how to use this in the doc's
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
  1. Tool Nose Radius Comp
    By lukehonor in forum G-Code Programing
    Last Post: 12-27-2010, 11:22 PM
  2. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  3. Tool nose radius comp. help needed
    By cuz1007 in forum G-Code Programing
    Last Post: 01-20-2010, 08:15 PM
  4. Help with tool nose radius comp
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-09-2008, 02:25 PM
  5. Tool radius comp
    By cijunet in forum Mastercam
    Last Post: 12-20-2007, 10:27 PM
