586,980 active members*
4,705 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Parting an R2E4 Series II control - any interest in the complete control panel?
    Feb 2005
    101
    I am nearing completion on my linuxcnc conversion on my R2E4. I am debating whether to sell off the complete control panel box (with the keyboard, monitor etc) or just sell of the bits inside and use the housing for a custom control panel. I know people like to buy the control panel keyboard since they wear out easily... not sure about the whole box though.
    At first I was set on throwing it out... now I think it might be a good spot to mount stuff.
    Feb 2005
    101
    I ended up parting it out. The SFM and CRT assembly are up on ebay now. If interested you'll find them (only ones on ebay!).
    My plan is to make an aluminum panel to replace the control panel which I can add my own buttons and controls too. I'll use the existing factory feed override potentiometer, quadrature job knob, spindle direction control and e-stop.
  1. Bridgeport Series II R2E4 to AJAX control and Variable speed removal
    By dougputt in forum Centroid CNC Control Products
    Last Post: 01-16-2014, 07:05 PM
  2. Parting TM02 Control from Emcoturn 140/240
    By Marty_Escarcega in forum EMCO Lathe
    Last Post: 12-31-2012, 01:55 AM
  3. Is a boss 3 control worth parting out?
    By jcox1968 in forum Bridgeport / Hardinge Mills
    Last Post: 11-19-2010, 05:35 PM
  4. Bridgeport R2E4 CNC Mill control problem
    By lyncomputer in forum Bridgeport / Hardinge Mills
    Last Post: 10-29-2009, 01:18 AM
  5. Series II BOSS 6 Control panel issue
    By btcoutermash in forum Bridgeport / Hardinge Mills
    Last Post: 04-05-2008, 11:56 PM
