I am new to cnc zone but I am having a problem with bobcad cutting a flat a the bottom of an arc. it is a flat piece of aluminum .69 radius running on top it is parallel to the flat stock so slice planner makes sense. I stepped over .005 at a time using a .125 ball endmill. my tool path inside bob cad shows a stop in cut on each side of the radius at the bottom until you remove the layer with the material in it then you can see the whole tool path. In the machine it is leaving a flat in the bottom of the radius and I am not sure why it is doing this. Any help would be much appreciated thanks
