Hi all
Just looking for a but of guidance with setting up my Lathe with a 6T Controller.
I'm have a issue of the G50 cmd not holding the correct location after you do a manual jog or handle operation. After doing a bit of hunting i found a post in this forum 'Absolute cords reset in handle mode'.
I'm wanting to know if my lathe is set up for abs or inc programming by default. What parameter address do i look at to find the setting of this data bit and what to change it to to set it to abs mode.
I tryed to run a G90 in the midi but that put's it into cutting cycle mode not ABS mode
Cheers
Snow
