586,832 active members*
3,149 visitors online*
Thread: Wont Read L0
Results 1 to 8 of 8
    Jul 2013
    31
    Wont Read L0
    Hi to you all, having a bit of a problem with the Fanuc Controller on a Dah Lih Machining Centre. The system does not seem to recognise the L0 on the end of a drilling cycle and therefore drills a hole where I don't want one. e.g.
    N10 G00 G56 X0. Y0. S1000 M3 (bolt hole centre)
    G43……...
    G81 G98 Z-0.1 R0.1 F2.0 L0
    M98 PXXXX (hole positions)
    I know I can avoid this problem by positioning the tool over the first hole on the N10 Line but there are times such as when using macros that I prefer to position the tool over the bolt hole circle centre.
    Has anyone else experienced this problem or know why it is happening?
    Many thanks.
    Sep 2010
    1230
    Quote Originally Posted by j206 View Post
    G43……...
    Many thanks.
    Specify the model of the control. L0 should normally work with most models, but you could try K0.
    Bill
    Jun 2007
    87
    G43……...
    Many thanks.
    uhhmm.. unless I'm missing something, your program is supposed to drill on the bolt hole center unless you put x and y position on the G81 line. If you don't want to put x and y positions on the drill cycle you have to call the position sub first before coding the drill cycle.
    Uly
    Jul 2013
    31
    Quote Originally Posted by angelw View Post
    Bill
    I think the model of the control is Fanuc OI Mc (?) thats what it says on the front of the control panel anyway. You could be onto something with the K as I had a look through one of my books and there is reference to Fanuc "O" using K instead of L. Unfortunately I didn't get chance to try it out today, had a big Inco job on that ran all shift, will try tomorrow.
    Jul 2013
    31
    Quote Originally Posted by uperez View Post
    Uly
    Hi Uly, maybe I am also missing something but I have used the stated method of L0 at the end of the drill cycle line many times no matter whether I had X0, Y0, included in the drill cycle line or not. You are right that a hole should be drilled at X0, Y0 if no L0 was included on the same line but the L0 should stop the drill operation from being executed at these co-ordinates.
    Jun 2007
    87
    wow.. this is something new to me. I always thought that L0/K0 was the same as without L/K on the drill cycle line, didn't know that 0 will cancel out the cycle on the position where the cycle was called.
    Thanks for this info.
    Uly
    Nov 2007
    355
    G81 G98 Z0.1 R0.1 F2.0
    X10.0 Y10.0 Z-0.1(HOLE2)
    X20.0 Y-10.0 Z-0.5(HOLE 3)
    X25.0 Y110.0 Z-0.1(HOL4 )
    X15.0
    Y15.0
    Try this as i dont know anyone still using that method --no reason anymore
    Jul 2013
    31
    I tried the G81 line this morning using the K0 on the end of the line and it worked fine (stopped the drill cycle from being executed at that co-ordinate) so problem solved. Thanks for the help guys.:rainfro:
    @ Uly, well thats one of the real joys of our job, you know, I have worked at a few different places all with their own particular pluses and negatives but one thing has always been a constant, you can be sure you will come across something new that you have not encounter before. I have been programming for around 15 years and I still have lots to learn. Thanks
  1. HELP Dwell code wont read.
    By bhbjb in forum Daewoo/Doosan
    Last Post: 06-01-2011, 05:52 AM
  2. Fagor wont read from serial port
    By PinMan in forum Fagor Automation
    Last Post: 10-08-2008, 06:00 PM
  3. Cent.4 wont read I or J help
    By Jeff S in forum Milltronics
    Last Post: 03-30-2007, 07:35 PM
  4. Must Read for All
    By CBNDude in forum News Announcements
    Last Post: 07-22-2005, 03:14 AM
  5. Need help installing windows 95 - cdrom wont read
    By Hack in forum Computers / Desktops / Networking
    Last Post: 02-15-2005, 05:03 AM
