586,892 active members*
4,554 visitors online*
Results 1 to 8 of 8
    Dec 2010
    337
    LS iC5 230V 1.5kW Inverter
    Hunting around for a cheapish inverter to power a 1.5kw chinese spindle and came across the LS (formely LG) iC5 230V 1.5kW.
    Has anyone got any hands on with the unit? I was hoping for a step up from the Huanyang VFD, with an english manual, uk supplier and a warranty, if only for a year and was hoping this one would do the trick. I've seen a lot of other units maed by a lot of other manufacturers but they're all abit out of my budget.
    Jan 2006
    357
    Yes I have one, Are you looking for the manual?
    Dec 2010
    337
    thanks gary, i'll take a look at that now, was wondering if they are reliable and since it's the first inverter i will have owned/operated trying to find one that will work with a cheapo 1.5kw air cooled chinese spindle. Do you have the 1.5kw version by any chance?have you used it much?
    edit. f@@k me, the manuals a full on bit of reading, was going to say is it easy to set up, loos like this is going to take a while.
    Jan 2006
    357
    Lol! yeah there are a lot of settings to mess with! I am happy with mine, its about three or four years old and it drives a two hp motor in sensor-less vector mode and it gets used a lot. Mine is 2.2 KW but it is basically the same. I don't know what the prices are like where you are but I don't think you would get much advantage using a sensor-less vector drive on a spindle but, if its the best price then it doesn't matter. On my cnc router I sometimes use large edge forming and plunge bits and it takes about everything my router can give to do it. Its a Milwaukee 3.5 HP router
    Dec 2010
    337
    There's a lot to look up, i think many of the features i wont be messing with to start with, as long as it powers up the spindle and lets me control it reliably. A lot of the inverters in the uk are expensive £300+, where as this one is only £130
    Jan 2006
    357
    No you probably not be using a lot of the features, By control it do you mean turning the knob on the front of it or or controlling it with your software? I can be done either way, I control it through mach3/linuxcnc. Still learning linuxcnc!
    Dec 2010
    337
    I'll be using the front of the inverter to start with, no automation. After wiring the inverter to the spindle i'd like to be able to turn it on, set the frequency and let it run. Eventually i'l work out how to command the unit with mach3 but important thing is to wire it into the spindle and get some cutting done without to much a fuss.
    Jan 2006
    357
    Ok. That's pretty simple
  1. chnc input voltage around 214-217 need 230v
    By snascar2424 in forum Hardinge Lathes
    Last Post: 08-16-2011, 03:05 AM
  2. Need Help! 5HP motor 460V to 230V?!
    By diyengineer in forum CNC Machine Related Electronics
    Last Post: 10-25-2010, 12:08 PM
  3. Rewiring Transformer for 230V Input
    By keebler303 in forum CNC Machine Related Electronics
    Last Post: 05-27-2010, 05:24 PM
  4. I need 3Phase 230V off 1Phase 110V, can I get help?
    By idtkid in forum CNC Machine Related Electronics
    Last Post: 07-14-2009, 02:56 PM
  5. Need help wiring 230V AC spindle motor
    By Heavy D in forum Knee Vertical Mills
    Last Post: 05-07-2006, 05:24 AM
