Ok my Allen Bradley contact finally pulled through for me and got me four almost new Bulletin 1326 DC servo motors. The Servos have military style connectors, I have all the wiring harnesses for them, and they are huge . I want to use them, not only because I have them, but they are a lot more efficient than stepper motors. I am making a homebuilt desktop sized machine ( about 30 x 40 inches) and i am really going to have to do some retro-fitting to get these puppies to work. I'll give you the stats:
Current: 5.5 A continuous, 30 A peak.
Torque stall: 3.1 lb-in
Max Speed: 5000 RPM
KE 7.4 v/k rpm
Tachometer 7 v/k rpm
Encoder 1000 PPR
The encoder is the AB 845P series integrated optical encoder, 100 PPR, and it has like 9 wires going out of it. Could someone please explain what these wires do. I looked at the data sheet, and it is just all greek to me.
I am pretty new to this stuff, and not even out of high school yet. I want my machine that I am working on with a friend to be able to do PCB work, but I also want to do a lot of other simple engraving and etching, maybe go on to some 3d cad stuff later.
I don't know what the tachometer does, someone elaborate. I took apart the motor and found what looked like a regular commutator with two brushes, and then there was like a super fine comutator with a lot of contacts and four brushes. I'm guessing the latter is the tachometer.
Could the Gecko 320 Servo Drive drive these? If not, what would?
