587,040 active members*
2,962 visitors online*
    Feb 2010
    23
    Hole locations G0704
    Does anyone know the exact location of the 4 holes (M12) on the back side of the base (in MM/IN) from the top & left/right side? There might be slight difference in between 2010 and later models.
    Jan 2010
    151
    is yours a 2010 model? what are your measurements as they can vary a little from machine to machine as the chinese aren't real careful about hole placement. i think they go by eye with handtools.
    am
    Feb 2010
    23
    Am, my G0704 is 2013 model. I wanted to avoid the Z post dismounting, so at this point I can only get the approximate data.
    Jan 2010
    151
    alright but the 2010 reference doesn't make sense then, i can't give you that data as mine is still together as well.
    am
  1. Locations
    By david parkhurst in forum Tormach Personal CNC Mill
    Last Post: 02-05-2014, 05:36 AM
  2. Please Help! Ports and Pin Locations on new X2 build.
    By DallasShooting in forum Benchtop Machines
    Last Post: 03-06-2012, 10:29 AM
  3. Someone please help with fuse locations
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 08-07-2011, 05:31 PM
  4. NM-145 Locations / Dimensions
    By cteufert in forum Novakon
    Last Post: 03-27-2011, 05:59 PM
  5. locations
    By mad_dog096 in forum DIY CNC Router Table Machines
    Last Post: 11-26-2008, 05:50 AM
