586,317 active members*
3,508 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > surface speed and feed rate calculator
Results 1 to 10 of 10
    Jan 2006
    48
    hello forum has anyone got calculator for determing the surface speed and feed rate of emd milld and slot drills please something that easy to use and on the internet ,,,,,all the best derkiow
    Apr 2003
    1873
    It is not free but it is the easiest to use I have found, it would be extremely useful for any level of machinist experience.
    Inch or Metric selection.
    Much more then speeds and feeds as well.
    Well worth considering, you can take a look at what it has to offer here.
    http://www.mrainey.freeservers.com/
    Mar 2006
    1625
    I use ME Pro the program Ken Shea is talking about the feed and speed are very good starting point. Also you can edit data base for tool and materail it's about $100 but you can save that in endmills,drills and scrap peices in not time. I find that it's something that I use just about every day
    Jul 2003
    1220
    Here is a simple VB program that I have written.
    It is very basic and use only as a guide.
    Attached Files Attached Files
    Jan 2006
    48
    a big thankyou
    a big thank you for your help , calculators very useful and easy to use :cheers:
    Jun 2006
    6
    surface speed in mdf
    hi.
    i have the same problem, but i need calculate the surface speed and feedrate in mdf. and i only find for metal materials. if you can help me, please. any way tank you.
    Jul 2003
    1220
    Miguel
    I can add MDF.
    What is the recommend cutting speed and feed?
    Is there different grades which requires different conditions?
    Jul 2003
    1220
    Angry conflicting information found.
    MDF added to calculator.
    Chip load is set at minimum .008in. maximum .016in.
    New version attached.
    As I have found conflicting chip loading information I have withdrawn this version of the calculator.
    I will modify and repost. Sorry for any inconveniance.
    Jul 2003
    1220
    Chip loading is set at minimum .001in. maximum .012in.
    Revised version attached.
    Jan 2006
    73
    I hope this work. I have a attached a speed and feed Cal.
