Drilling - Drill presses, mills, hand drills, etc.
Tooling - Drill bit
Routing - Wood router, table router, edge router, etc
Tooling - Router bits
Milling - Mill, Bridgeport, 4- axis mill, 5-axis mill, vertical mill, horizontal mill, etc.
Tooling - End mills, ball mills, ballnose mills, fly cutters, etc
Plasma cutting - Plasma cutter
Tooling - Plasma torch
Cutting - Chop saw, hand saw, band saw, cold saw
Tooling - Circular blades, band type blades
Grinding - Surface grinder, grinder, Timesaver, belt grinder
Tooling - Grinding belts, grinding wheels
Turning - Metal lathe, wood lathe, mini lathe, bench top lathe, etc.
Tooling - Turning tools, parting tools, boring tools, drill bits
