I'm doing an electronics project where I need to fasten two conductors together (busbars). I think I need to use regular steel fasteners since the whole construction needs to be assembled before soldering, so everything will be heated to something like 250-300°C and nylon bolts won't do. So I'm trying to make some heat resistant spacers that will electrically isolate the steel bolt from one of the busbars. So I searched for heat resistant plastics, and stumbled upon bakelite. Bakelike is used for the handles on frying pans, and the kids happen to have an old frying pan in the playhouse, so I confiscated that (no kids were harmed during the confiscation) and started turning using a carbide insert normally used for steel.
The bakelite usually contains a filler, which may be anything from clay to glass fibre according to what I have read. It still turnes fine though but it is a bit rough on the HSS twist drills.
Anyway, I need to turn a tube ID 3mm for the bolt, OD 4mm to keep the hole in the busbar small. But the bakelite is a really brittle material and it breaks real easy. I tried turning the piece to OD 8mm and then drill the 3mm hole, and then turn it down to OD 4mm, that last 2 cuts were 0.5mm at a time. But the bakelite broke on the last cut.
So, either a recommendation of some other easy-to-get material that is an electrical isolator, heat resistant and machinable OR any recommendation on how to turn this small piece without breaking it.
Thanks.
And sorry for the really long post, but I like to include some background information ;-)
Best regards,
Martin
