Originally Posted by
Simonh1959
I have been using a Powermax 105 on my Blue Marlin CNC for about a year now and getting good results, there are just two things though that I would like to improve on;
Firstly hole quality, although the holes I get are good there is obviously still a taper on them which means that on thicker material I have to oversize the hole to achieve the required diameter on the bottom side of the plate.
Secondly cutting stainless steel, we do this quite successfully but it does leave a black finish which we have to sand/grind off (we have tried using nitrogen which does give a brighter finish but also increases the dross that needs to be removed). We currently have a regular order for s/s rings but due to the time required to clean them up I find it cheaper to buy laser cut ones which puts me at the mercy of the laser cutters delivery schedules.
The Blue Marlin that I have is actually a high definition machine as I bought it with the intention of upgrading to HD at a later date and I have been offered a good deal by my supplier to part exchange my PM 105 for either a Max-Pro 200 or one of the other HD units available but the Max-Pro 200 is the only one within my budget. We are only a small jobbing shop so the maximum number of items that we cut would be about 50 off so I am trying to work out if upgrading would be worth the extra outlay?
Any thoughts or advice would be appreciated.
