587,006 active members*
2,894 visitors online*
Results 1 to 6 of 6
    Sep 2007
    84
    Multiple profile operation tool path issue
    Hello,
    I have a problem when running a tool path for multiple profiles in one operation. The operation is set to the left which should be inside the pocket (see screen shot). Yet 3 of the paths are outside or opposite side of the path. I haven't made any changes that i believe would cause this. The project is a Star Wars Empire logo.
    Any thoughts? Thanks
    Attachment 220152
    Attachment 220154
    Oct 2013
    64
    You can edit every single path for right or left side. At the geometry.
    Sent from my Nexus 4 using Tapatalk
    Feb 2013
    49
    1st, the direction of the geometry selected affects the tool position (left or right). 2nd, as explained, you can change whether the tool will be at the left or right inside the profile operation parameter. if you don't have a good practice at the 1st control, you will always need to play with the 2nd control.
    Oct 2013
    64
    It is always recomended to work at left side of the geometry (whan you work m3), so you sould change the direction of your particular paths that goes to the wrong direction.
    Feb 2013
    49
    by default, the profile operation is always at left. It is recommended to use climb cut for profile operation. if you are cutting inside wall, geometry direction must be CCW. if you will be cutting outer wall, geometry direction must be CW. You make this a habit, you don't need to worry about left or right inside the profile parameter.
    Sep 2007
    84
    Gentleman,
    I do recall not all of the paths going the same direction. I'll make your information practice. Thank you for your help.
    Craig
  1. Profile tool path
    By Bradferguson in forum PhotoVCarve and VCarve Pro
    Last Post: 01-17-2014, 03:54 AM
  2. EDGECAM PROFILE CYCLE GIVES ME UNEVEN TOOL PATH
    By prasad_slb in forum EdgeCam
    Last Post: 05-20-2013, 05:29 AM
  3. Replies: 10
    Last Post: 09-05-2012, 03:30 AM
  4. Different tool path with different profile
    By vcatalasan in forum Mach Software (ArtSoft software)
    Last Post: 08-18-2011, 06:28 PM
  5. Tool Path Generation Issue
    By ianober in forum BobCad-Cam
    Last Post: 03-11-2009, 07:42 PM
