587,035 active members*
3,144 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Machining ceramic on the Torus-Pro
    Mar 2011
    480
    So... I had a job requiring some specific material properties come up. It had to handle 400 deg C and be non conductive. I'm basically heating a device electrically at 10 amps @ 1.5 Vdc. using to electrodes I machined from copper. I had kicked around the idea of machining out of steel and having a coat of ceramic fired onto the surface. Did some research and found out Corning makes a ceramic that is machinable with metal cutting tools called Macor. So I designed the part and ordered a piece of 1.75" x 1.75" x 3". Piece of stock for $120.00. In the mean time did some searches on machining the stuff. After reading lots of horror stories (chipping,fracturing from too much holding force etc), I was very apprehensive about making the part, but my time table wouldn't allow outsourcing the part.
    Looking at the manufacture's recommended cutting data, I thought it was a mis-print. Incredibly low surface speed required. 35 SFM. I had to machine all 6 sides with intersecting .07" holes and thread milling. This was going to take forever at those speeds/feeds. Oh well, too late to turn back now.
    Job 1. Slice the stock down to 1.2" in the Z dimension. I don't have a saw that will turn that slow but I do have a slitting saw for the Torus with a .625 arbor. So went to home depot and found a 4" diamond cutoff wheel. The arbor was not an ideal fit, but doable. Ok, that worked good enough, but now it's time to machine.
    After reading about work holding challenges, I decided to slice some soft aluminum (sheet metal type) to support the material between the steel jaws. I put enough pressure to hold the material for what I "felt" would work, and programmed some conservative depths of cut to reduce cutting forces. Then I made a make shift flood cooling setup required for machining Macor (I normally use high pressure mist). After a whole day of "pucker factor" I got the piece made and it came out GREAT!. Took an extensive amount of cleanup afterward. I hope to never have to machine this stuff again, but now I know I can.
    Here's a short shaky cell phone video.
    Macor Ceramic AM - YouTube
    Jul 2006
    525
    Ick..
    Jan 2012
    469
    That was nerve-wrackingly cool.. And now that I know that, I'm sure it'll come in handy some day hehe.
    Dec 2009
    594
    Pretty expensive material!
    Yeah I remember working with that stuff at work, had to slice off dozens of parts about 1/8 inch thick with a slitting saw, bummer was it was on a manual bridgeport and took forever at the slow cutting speeds but at least I got paid for it.
    Hoss
    Sep 2006
    1738
    Nice I have ceramic in my room from my brother; un-sintered though...
  1. Torus Pro vs Torus vs Pulsar vs PM45-CNC
    By Titaniumboy in forum Novakon
    Last Post: 01-28-2014, 06:47 PM
  2. ceramic tile ??
    By cyclestart in forum DIY CNC Router Table Machines
    Last Post: 07-04-2013, 11:25 PM
  3. Machining ceramic
    By ndog in forum Tormach Personal CNC Mill
    Last Post: 07-27-2011, 07:37 AM
  4. Ceramic Inserts
    By Hellbringer in forum Mini Lathe
    Last Post: 06-30-2009, 02:34 PM
  5. Ceramic Inserts
    By Turbine in forum Community Club House
    Last Post: 09-25-2003, 03:23 AM
