586,700 active members*
2,631 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor noise and grinding
    Mar 2011
    Hi everyone, so I got this desktop cnc mill, that I'm planning on using for milling some pcbs, but I've ran into the following problem when I try to link it up with mach3, the motors make this grinding noise and are running kinda rough, but when I use the manual axis control that connects directly to the controller everything runs smooth like butter! I've tried changing the motor settings in mach3 but the noise seems to be there regardless of settings it changes in pitch and intensity when I tweak the settings but nevertheless it's there and is really disturbing. Any help is truly appropriated!
    Sent from my HTC VLE_U using Tapatalk
    Jan 2014
    5
    Hi motion86,
    you should adjust motor tuning and enter the right step per
    go to config>motor tuning
    Attachment 219800
    change in speed & acceleration untill you reach the comfortable sound. Do not forget to press save axis setting
    Mar 2011
    It wasn't that, but turning on the sherline 1/2 pulse mode fixed it.
    Jan 2014
    5
    that is good
    good luck
  1. Stepper motor noise?
    By Drools in forum CNC Machine Related Electronics
    Last Post: 02-16-2013, 01:34 PM
  2. Stepper motor high frequency noise!
    By speedydumpster in forum LinuxCNC (formerly EMC2)
    Last Post: 02-16-2011, 06:59 AM
  3. Stepper motor noise
    By speedydumpster in forum Benchtop Machines
    Last Post: 09-02-2010, 11:55 PM
  4. Stepper motor noise
    By dmparrott in forum CNC Machine Related Electronics
    Last Post: 10-03-2007, 04:35 PM
  5. MACH3 and noise from stepper motor
    By timeout555 in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2007, 04:39 AM
