586,129 active members*
2,782 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Solidcam transform toolpaths around 4th axis problem?
    Jun 2012
    19
    I'm working on small job for a customer and I'm milling a 3.5" x 8" long round stock of aluminum in to a hex shape. I setup my tool paths and verified them in the solidverify in solidcam and everything is fine. However when I post it out, it shifts the Y position after every other A value when it rotated to the next side. So the first cut is fine and then when it rotates 60 degrees and begins to cut the exact same tool path, it shifts the y value that calls out the starting position to about 1 inch over... Weird, I have looked through all my settings and have found nothing unusual. I think it might have something to do with a setting I missed or the post processor. If someone could please give me some help it would be greatly appreciated. Thanks
    Im using a 2004 Fadal 4020ht with a VH64 rotary table.
    The part origin is setup in the center of the rotation and parallel with the X axis.
    Jun 2012
    19
    Part Pic
    I posted a pic of what I'm working with. Any help would be nice. Thanks
  1. solidcam 2010 no transform for machine Hurco
    By Bogdan_Celtic in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-29-2013, 12:06 PM
  2. Transform problem
    By Sinij kot in forum Mach Software (ArtSoft software)
    Last Post: 01-17-2011, 08:00 PM
  3. Transform Problem Solved !!!
    By mongo46538 in forum UG NX
    Last Post: 12-16-2009, 01:48 PM
  4. Transform problem
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-07-2009, 09:01 AM
  5. Using Transform Toolpaths
    By data-matique in forum Mastercam
    Last Post: 12-22-2008, 07:04 PM
