586,745 active members*
6,499 visitors online*
    Nov 2013
    7
    G0704 mach3 steps per
    I recently finished converting my mill to cnc. I am having a issue with dro not reading correct. When I jog the table 1" by measuring with ruler, the dro reads 4.043. The only way I can the dro to read correct was to set the steps per to 8088 and it close, not perfect.
    Setup:
    520 oz on x and y
    1605 ball screws on x and y
    Kl8056d driver
    906 oz on z
    2505 ball screws on z
    Kl8070d driver
    What do you have the dip switches set to on your driver? seems to be 1/8.
    The 8056 can be the same as I have for the 5056 here on #6.
    FAQs
    This would be for 1/8 microstepping so the steps/per would be 200 x 8 x 5.08 = 8128
    200 is the steppers steps per rotation
    8 is for 1/8 microstepping
    5.08 is the 1605/2505 ballscrews pitch imperial, 25.4/5=5.08
    Hoss
    Nov 2013
    7
    I set the dip switches, the way you said to do on you page.
    ok, set the steps/per to 8128 and you should be good.
    Hoss
    Nov 2013
    7
    Will do, when steps per is set to 8088. For x and y volecity is set to 100 and accel is 100. For z the max I can do is volecity 50 and accel is 45. If I do anything else it freezes.
    Austin
  1. Steps per in mach3?
    By mw29715 in forum Mach Software (ArtSoft software)
    Last Post: 06-25-2011, 08:49 AM
  2. Mach3/G540 Steps per inch
    By AlbertaClipper in forum Gecko Drives
    Last Post: 12-06-2009, 06:11 AM
  3. C6B Calculate steps for Mach3?
    By john_t_h in forum Syil Products
    Last Post: 11-07-2008, 05:46 PM
  4. Steps per/mach3 config
    By bp092 in forum Gecko Drives
    Last Post: 02-22-2008, 07:49 PM
  5. Losing steps with Mach3
    By CMPM in forum Mach Plasma / Laser
    Last Post: 07-20-2007, 04:02 PM
