When programing a profile tool path what if the difference in the three settings
Outside
Inside
On
When cutting using the outside setting will work piece be larger when completed?
When cutting using the inside setting will work piece be smaller when completed?
When cutting using the on setting will the cutter cut right to the line and be more accurate?
