587,006 active members*
3,051 visitors online*
Thread: Bad corners
Results 1 to 7 of 7
    Feb 2011
    308
    Exclamation Bad corners
    Hello
    I made a project with vetric. But when I go to 3D View tab and run toolpaths preview it showed me that in some corners my tool will travel too far and these corners will be bad.
    Is there something wrong with the set up? Did anyone of you ever experience the same problem? I'm talking about the inside corners
Name:	bad corners.jpg
    Jun 2008
    562
    Maybe your vectors are open(not joined)???
    Mike
    Feb 2011
    308
    I already checked that. And they are joined
    Jun 2008
    562
    Can you post the project file without the center floral design?
    Feb 2011
    308
    Here you go. I have to make zip file because it won't let me upload .crv file.
    Attached Files Attached Files
    Jun 2008
    562
    You have 41 open vectors, they may look joined but, Nada. Highlight all the vectors and hit the "J" key. It will tell you how many are open and the resultant number of closed vectors after joining with the specified tolerance. The tool path was starting and stopping at each endpoint. Let me know if that works for you.
    Good Luck
    Mike
    Feb 2011
    308
    It did!!! Thank You so much. It looks like I need to learn more about functions in VCarve.
  1. Square corners
    By bjay in forum CamBam
    Last Post: 09-26-2011, 02:20 AM
  2. How to Radius corners of a box.
    By Xterrian in forum G-Code Programing
    Last Post: 06-24-2010, 05:09 AM
  3. cutting corners out
    By galaxyman7 in forum Mastercam
    Last Post: 12-11-2009, 02:33 AM
  4. Sharp corners
    By renato13 in forum Fanuc
    Last Post: 08-28-2009, 02:51 PM
  5. Breaking corners
    By cijunet in forum GibbsCAM
    Last Post: 12-30-2007, 05:37 AM
