586,565 active members*
3,430 visitors online*
Page 2 of 3 123
Results 21 to 40 of 44
  1. #21
    Jan 2013
    119
    ger21
    Unless your board is shorted internally (highly unlikely), imo the "Limit Switch Triggered" message indicates a noise issue
    Then I re attached the existing cable to the probe. As soon as I attach the alligator clip to the bit message says either "Estop" or "Limit Triggered" Every time I do this, the message alternates to one or the other.
    How about the possibility of a external connection changing the pin state on all outputs at once?
    I know it's hard to tell without a complete schematic, and software configuration.
    This thread is not finished yet.
    What do you think?
  2. #22
    Jan 2013
    119
    Am I correct here?
    You are connecting 5V+ through a 56-1K resistor then connected to the tool bit.
    Your plate is connected to pin 13 on the BOB.
    when the tool bit makes contact with the plate pin 13 goes high.
    I'm having a hard time seeing how this works.
  3. #23
    Mar 2007
    2083
    yes
    thats what the diagram in post 17 shows and only works when the spindle is insulated
    and the jumper set to pull down the input via the 4K7 resistor on the PCB
    the added resistor is optional and protects the +5V supply from an accidental short circuit
    John
  4. #24
    Jan 2013
    119
    Your plate is connected to pin 15 on the BOB.
    when the tool bit makes contact with the plate pin 15 goes high.
    Why are you connecting this 5V+ to ground ? Seems to me that this maybe the reason why
    the EStop and limits are tripping. because its pulling all the outputs low on the input header.
    I do not believe that this is a noise problem.
    The error message about Estop or Limit trip error message shown depends on which Mach recognized first.
    I'M assuming that you have 5V+ connected through the Estop switch then to pin 10 on the bob.
    I'M assuming that you have 5V+ connected through the limit switches then to pin 13 on the bob.
    These connections have no current limiting resistor. Why aren't these getting hot ?
    Why Use such high wattage resistors in a TTL level circuit ?
    Shouldn't the solution for fixing one problem not create another problem ?
    When I identified this problem ( Post # 7 on this thread)
    I didn't have to explain my how I would approach solving your problem.
    There is more than one way to fix most any problem, it's up to you to decide which approach to take.
    Attached is a schematic of what I would do it.
    Attachment 218926
  5. #25
    Mar 2007
    2083
    Hi mzones
    the 1K pull up resistor in post 11 is the simplest solution
    that did not require making a PCB and only uses one component
    that can be secured by the C10's terminals
    in view of the limited range of resistors Nicolas had to hand for the initial tests
    and the limited range of resistors available in his local store
    I selected the 36 ohm 10W resistor Nicolas had for the initial tests
    and in post 19 a range of 1/8 or 1/4 watt resistors to buy to complete the installation
    (a 36 ohm 1 Watt resistor across the 5V supply will only take 0.138 A
    and should not be a problem either)
    the alternative circuit in post 17 has the resistor added to protect the 5V supply
    as I expect its more likely to be short circuited by accident
    than the positive supply to the E stop or limit switches
    without any other details I expect the other issues may be due to the jumper being
    in the pull up position at some point since the BOB is now working correctly
    John
  6. #26
    May 2009
    1332
    Hey Mzones why you try to make life more complicated? John provided an excellent simple solution to the problem I had and now all is working fine.
    Which problem you identified in post #7? I see nothing there
    And what do you mean about "These connections have no current limiting resistor. Why aren't these getting hot?"
    All pins 10-13 and 15 are set to pull down
    Yes there is more than one way to fix any problem and John choose the simplest including parts I had available. Good show John
    Nicolas
  7. #27
    Quote Originally Posted by kolias View Post
    I think he just wants to know why you were getting the results you were getting. Knowledge is never a bad thing.
  8. #28
    Jan 2013
    119
    The probe consist of an alligator clip which is connected to the GND and a metal plate which is connected to an input pin on C10
    Here at your first post there two different problems.
    At this point input pins are set to 0 volts, (jumper set to pull down.)
    Pin 15 is connected to the plate. Probe is connected to gnd on the BOB.
    When the probe makes contact with the plate this creates continuity between
    pin 15 (0 volts) and gnd.
    Therefor the circuit you have described here, is switching 0 volts to ground
    Switching 0 volts to ground isn't going to do anything.
    A problem identified post#7 !
    "Limit Switch is Triggered" tells you not that the tool hit the plate, but that a limit switch was triggered. What this means is that you either have the plate wired to a limit switch input, or, noise is triggering your limit switches when the tool touches the plate. The bit doesn't rise 1" because Mach3 is stopping on the limit switch trigger.
    With the limit switches in there normal state 5 volts is sent to Pin 11 setting it high.
    The way you had it wired at this time. probe contact sends pin 11 low triggering limit switch.
    This totally explains this issue.
    A problem Identified by ger21
    Attaching the alligator clip to the bit you created a path sending output pins low ,
    triggering Estop and limit switches Like maybe you had the alligator clip connected to the
    5 volts of the input pin section. this would explain this.
    I agree that this will work IF the spindle is isolated.
    I'm curious though just how you plan on getting the spindle isolated.
    This seems to be another problem created by the approach that you are taking.
    The circuit I posted here does not need to be isolated, nor would it
    create other problems that you have encountered here.
    Just do it as a bug.
    Like I said about different people having different solutions for the same problem,
    here is another one of my prospectives.
    Put simply this could also be done by using pull up jumper setting., Sinking the Estop limit switches
    and the probe signals. This would not require any external resistors, as they are already in the BOB
    As to making this complicated Maybe l can go into my personal configurations and invert the signal for that pin.
    I'm not your doing a mighty fine job on your owe!
    Mike
  9. #29
    Aug 2016
    185
    Re: Zero Touch Probe problem
    Quote Originally Posted by john-100 View Post
    Hi Nicolas
    Great , just the result we want
    its just a matter of having the probe pulling the input in the opposite direction to
    the on board pullup / pull down resistor
    (not always easy see if you spend too long looking with out a break )
    the resistors maximum voltage is not going to be an issue since the circuit only has a 5V supply
    using a 1/4 watt resistor any thing from 120 ohms to 1000 ohms will be OK
    with 1/8 watt resistors use 270 ohms to 1000 ohm resistors
    (the values are high enough not to run the resistors at the maximum wattage
    I aim for 70 to 80 % of the maximum )
    if your local store is like the Tandy ( Radio Shack) stores that used to be in the UK
    then 1/4 W resistors like this will be OK -
    E3 Series 480 piece carbon film resistor kit | Rapid Online
    or 1/8 W resistors like this :-
    Not Found | Rapid Online
    the 36 ohm 10 watt resistor you are using should ony be warm if the probe is permanently in contact
    with the touch plate
    ( 5/36 ) X 5 = 0.69 W
    which is only 6.9% of its maximum (10W)
    John
    I am doing this as we speak. So I wanted to throw this out and see if I am thinking correctly. My mill id all metal and the chassis is grounded to AC ground. I have a touch off plate i bought and the back side is non conductive. Just to prove this works I disconnected the AC ground and used the clip lead with 5V on it to connect to the touch off plate giving me and active high on the BOB. The touch plate is .757 high and hard to deal with on X and Y axis. So could i not just jumper my BOB to pull High and then connect the touch plate to input and set mach for active low. When endmill hits touch plate get a ground...
    I was thinking about using a printed circuit board that has not been etched for a touch off plate... Since I am going to need this everytime I Auto Z y or x ..
    Ideas comments...
  10. #30
    Mar 2007
    2083
    Hi truckeic
    which breakout board do you have ?
    Is the spindle connected to the mains earth / ground ?
    Or are you using a dremel type of spindle that's isolated from the mains earth ?
    connecting an isolated touch plate or piece of copper clad board to the BOB input will ground the input when a grounded tool touches the touch plate or copper board
    you can have electrical noise problems when the BOB's input ground is connected to the machines mains earth / ground
    John
  11. #31
    Aug 2016
    185
    Hi truckeic
    John
    I have a Harbor Freight X2 Mill. and yes the spindle is grounded through its bearings and such to ground. When (for test purpose) lifted the earth ground I could use a active high (clip lead with 5v) on the spindle and then a isolated touch off probe. I would like to use the X and Y zero scripts that i have gotten but since the spindle and my part are both ground that won't work. I would assume all these CNC mills are grounded but maybe some of the spindles are not. I do not want the AC ground to be lifted so my best way to make this work is tie the controller ground to the mill chassis and use active low.
    I am all ears to find a solution to this if you can offer one.
    Thanks!!
  12. #32
    Mar 2007
    2083
    John
  13. #33
    Aug 2016
    185
    John
    Sorry forgot to say...
    I have the CNC4PC C11G
  14. #34
    Mar 2007
    2083
    now I know it's a C11G
    the next question is is it connected to a desktop PC or a motion controller ?
    with the C11G you have the advantage of individual pull up/pull down jumpers on each of the five inputs
    set the touchprobe input to pull up
    with the C11G connected to a desktop PC
    the C11G input ground will be connected to the PC's mains earth
    the Harbor Freight X2 Mill spindle and table connected to its own earth
    an isolated touch plate connected to the C11G input should work
    provided you don't have noise problems due to the interaction of the two earths
    connecting the C11G input ground to the Harbor Freight X2 Mill table or spindle will form an earth loop
    depending on the answers,
    connecting the touch plate via an opto-isolator will solve an earth loop problem
    John
  15. #35
    Aug 2016
    185
    John
    Connected to a desktop. I am using parellel port.
    I have a 4 channel opto isolator.
    Do you have a schematic of connecting that up.
    I truly appreciate your help
    Sent from my XT1635-01 using Tapatalk
  16. #36
    Mar 2007
    2083
    this is a very basic diagram to add a PC819 opto isolator to a C11G input
    Attachment 421414
    if you add a link to your 4 channel opto isolator
    I will add more details just for your opto-isolator
    some opto-isolator boards have transistors connected to the opto-isolator output transistor
    John
    PS
    a random opto-isolator PCB example
    Attachment 421416
  17. #37
    Aug 2016
    185
    John
    PS
    Ok This is what I have here:
  18. #38
    Mar 2007
    2083
    I have found this circuit diagram for your opto-isolator board
    Attachment 421466
    the 3K resistor connecting the opto-isolator collector to terminal V1 is higher than I would expect
    (if it was near to 300 ohms I would of connected the photo transistors emitter / output GND to the BOB's GND )
    if the resistor values on the opto-isolator are correct I would connect it to the C11G like this
    Attachment 421468
    when the tool touches the touch plate
    the LED indicator will be on and the photo transistor inside the "817" opto-isolator will switch on
    This connects the BOB's +5V via the 3K resistor to the BOB's input
    the printer port pin should switch from a logic low (0V) to a logic high ( +5V)
    In Mach 3 set the input to active high
    John
  19. #39
    Mar 2007
    2083
    looking closer at the photo of the PCB
    it looks like the resistors fitted are 1K (marked 102) instead of the 3K shown on the circuit diagram found on line
    Attachment 421508
    John
  20. #40
    Aug 2016
    185
    John
    Great information and great drawing... Thanks I will be hooking this up. I am considering hooking all the inputs to the BOB through the Opto board just to clean things up. How much do you know about Index pulses. I built a Hall effect sensor and I am getting a reading but i am not sure its accurate. MACH3 says one speed and the Index says another.
Page 2 of 3 123
  1. Touch Probe
    By Babba in forum Syil Products
    Last Post: 03-11-2022, 04:36 PM
  2. 3D touch probe
    By bschwand in forum MetalWork Discussion
    Last Post: 12-26-2013, 10:06 PM
  3. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  4. Touch probe
    By kolias in forum Mach Software (ArtSoft software)
    Last Post: 09-08-2012, 11:16 PM
  5. Heidenhain iTNC530 touch probe problem
    By jan.van.gent in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-15-2012, 12:31 AM
