586,882 active members*
3,958 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > USB SS, Mach3, DG4s and DC motor for spindle
    Jul 2012
    159
    Oh I am setting up a lathe. I connected everything by the instructions in the manuals for each item, I set the pins and ports on Mach3 tab, spindle step to pin 1 port 1 and direction to pin 2 port 1, turned on spindle control in Mach3
    The SS powers up, and I get the green flashing light.
    According to the tunning software for the DG4S the encoder and all is working and communicating.
    I have blinking green lights on both smoothstepper and on the DG4S, but nothing moves.
    Help please it is driving me crazy
    Jul 2012
    159
    OK, UPDATE.....I got it moving, seems that the 5V signal from the C25 was not getting enough power from the smoothstepper board so I went with a higher mA walwart transformer, good to go, I can trigger movement now. However now in the servoconfiguration software when I hit the analyize button so I can see what the current PID settings do, the servo turns the lathe head 180 degrees and them reverses 180 degrees, then repeats it. It is very smooth but I need it to go in one direction.
    Any Ideas?
    DC Perm Mag 3.2 hp motor
    DG4S
    AMT-102V encoder
    SS with C25 board.
  1. Replies: 2
    Last Post: 03-26-2014, 03:15 AM
  2. Replies: 3
    Last Post: 01-15-2014, 11:26 PM
  3. Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
    By Ozzwinkle in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2013, 07:01 PM
  4. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  5. Can i use/setup a servo motor as spindle in mach3
    By schwinndk in forum Mach Software (ArtSoft software)
    Last Post: 03-06-2010, 07:00 PM
