586,471 active members*
3,542 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Alarm code "1011 ATC OR MAGAZINE MOTOR OIL"
    Jan 2014
    4
    Sorry to bother you all, but I'm getting really frustrated. I'm running an older Hardinge VMC 1500 2, and the darn thing threw a 1011 ATC OR MAGAZINE MOTOR OIL alarm on me this morning and I'll be danged if I can find anything anywhere about it. Machine has a Fanuc Series Oi-M controller.
    Is there someone here that can help me so I can get this darn machine back up and running. I have checked every oil, line, you name it and everything looks ok and fluid levels full....
    Jan 2014
    106
    Check all the monitoring circuits for Oil such as lube monitors (if any), Pressure switches Just look at the input diagram to see if these are satisfied. If you have filled all oil areas then it must be a control issue or some lube lines are clogged. I am not familiar with the mechanical layout of this machine though. Hope it helps some
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. "Breakout board & motor controllers" v "Stepper motor driver controller board"
    By atkinsonp in forum CNC Machine Related Electronics
    Last Post: 10-21-2013, 09:41 PM
  3. "Alarm - Bad Number" and commented code
    By thomax00 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-16-2012, 05:31 PM
  4. Replies: 2
    Last Post: 07-03-2010, 12:27 AM
  5. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
