586,685 active members*
2,965 visitors online*
    Apr 2012
    27
    Desktop Mill advice needed
    Hey everyone. Ive posted a couple times here, mostly for build advice. I was going to build a stout cnc router but instead realized a desktop vertical mill would benefit me more because I also have to mill more small (1.5" x 3" max) steel parts than large aluminum parts. Which is the most cost effective machine on the market capable of handling 4140 steel on a daily basis? Or would it be more wise to source a heavy duty spindle, used ball screws, and linear guides to build a machine? As you can see my work envelope is small. Would a Taig hold up milling 4140 if the feeds and cut depths were kept conservative? Thanks.
    Nov 2009
    4415
    A Taig would do the job most likely but not in a production atmosphere. Do you mean daily making the same part in steel? How many parts a day?
    Apr 2012
    27
    Thanks for the reply! Technically it would be production but that would be about 2-4 parts a day. And each part would be smaller than a rubiks cube.
    Apr 2004
    5742
    If that 4140 steel is hardened, you'll have problems machining it on any mill. But if you anneal it before attempting to machine it, the Taig will be able to deal with it. Heat-treat it after the machining is finished. The Taig will need periodic adjustment to deal with wear, if you're using it every day, and frequent lubrication, but it's a very cost-effective machine for making small parts like this. The relatively fast spindle gives it an advantage over most larger mills when using very small tools, which are likely to be necessary for your small parts.
    Andrew Werby
    ComputerSculpture.com ? Home Page for Discount Hardware & Software
    Apr 2012
    27
    Thanks for the info, glad to hear its capable. It will be annealed 4140. I will harden afterwards. 4130 could work for me too and might be easier to mill. I'll have to check the specs.
  1. PCB mill advice needed
    By macross in forum PCB milling
    Last Post: 03-26-2013, 04:08 PM
  2. Small desktop mill - New builder, advice appreciated
    By jestah in forum Vertical Mill, Lathe Project Log
    Last Post: 07-27-2011, 02:43 PM
  3. Need Advice on a Desktop Mill
    By LatheMaster in forum Benchtop Machines
    Last Post: 11-15-2010, 08:33 PM
  4. Advice Needed For Selling A Mill
    By TZ250 in forum Community Club House
    Last Post: 05-07-2008, 06:43 AM
  5. Series I mill - some advice needed
    By acerocket in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2007, 08:46 PM
