boundary problems, tool cutting across boundaries
BC Ver 25 Win7.
I make molds to pour lead in. Most of my molds are made the same way with different sizes and different shapes. the problem I have a lot is the tool cutting across or cutting outside of a boundary. I change the Milling tolerance and try different settings and can't seem to get it to stop. when you open the file you can see the stay toolpath running across where it shouldn't.
the section you will see when you open the file is a hook eyelet and I would prefer it didn't have that line across it when you do the simulation it looks good until it make that line across it. I have used a profile cut on this when the hook diameter is close to my tool size but this one is .052". I always do something to get by but was hoping for some kind of epiphany.:tired:
thanks!
David L. Aery
www.hooksolutions.com
