If it helps, I just finished circle milling a 5" diameter hole with a 1/2" 2-flute endmill, 1.25" deep.
I helical-milled it, dropping .050 per revolution.
Ramping down on every pass is less stressful on the endmill.
I was running the endmill at 3000 RPM, with a feed of 15 inches per minute (.005 per rev.)
Full flood coolant, and brushing the chips out of the groove every three or four passes.
It worked great.
